turbo???
Old Oct 21, 2004 | 03:27 PM
350f_bird's Avatar
Car: 91 firebird formula 350 or 94 grand am se
Engine: 350 or 3.1
Transmission: 700r4 or what ever a grand am has
turbo???
Has anyone tire the turbo in the back yet?
I was just wondering if you liked it?
Old Oct 21, 2004 | 05:46 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Here is my RMT:
https://www.thirdgen.org/techbb2/sho...hreadid=238864
Sorry it isn't an f-body, but I love my system. It has put my Cavalier up to speed woth a lot of V8 Mustangs and F-Bodies. It now has 180,500 miles on the stock engine (7,500 on the turbo system) and has run a best of 13.9 at 99mph!
Old Oct 21, 2004 | 09:08 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
You know Im still thinking about doing this with my 91S10
I have a 60/63 T3 layin aorund.
Im actually thinking of puting it up in the frame rail in the cat area though. little less pipeing to run.
Old Oct 22, 2004 | 12:06 AM
nightrider87's Avatar
I'm thinking the .60/.63 might be a little big?
If he has some slowing spools with the .42/.48s.... then again, he's running a 2.2.
Cara asked me about doing something neat with her car...this came to mind. .60/.63 might just work out on the 3.1 though maybe a .60/.48 would be better?
Old Oct 23, 2004 | 11:44 AM
89JYturbo's Avatar
I actually have a 2.8 V6 in my Z24. The turbo has no problems producing 10psi at 3000rpm. In first gear, it doesn't reach full boost because the engine accelerates to redline before the turbo can catch up but as soon as the hammer is down in second, its all in.
Chris, what engine is in your S10?
BTW, wait until you see the S10 I'm working on right now. I'm building it for the guy that did the body work on my IROC (we swapped labor). We're installing an LT1, a T56 and of course we'll be building a custom single turbo system for it. You will get the piping for ceramic coating once we have it fabbed up.
Old Oct 23, 2004 | 05:45 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Should be a awesome S10. if mine was in better shape id V8 it also.
Its a 91 2.8 V6 5spd wish it was a the 4.3 but oh well. Its a winter beater.
Old Oct 23, 2004 | 06:44 PM
In terms of turbo sizing for this sort of setup....
would a 3.1 V6 be better suited to the .42/.48 or a .60/.63? or posisbly a hybrid between the two?
Old Oct 23, 2004 | 09:03 PM
89JYturbo's Avatar
If you map it out, the 60 trim T3 is as good a match as you can get as far as the compressor side goes (at 10psi boost). I would try the .63 tubine housing and if response is not as good as desired, install a .48 housing. If you want to keep the flow up, install a stage III wheel with the .48 turbine housing.
My guess is that the 60trim compressor coupled with a Stage III turbine wheel and .48 housing is going to be a great match for a RMT (remote mount turbo) on a 3.1V6.
Old Oct 23, 2004 | 10:29 PM
how much of a difference does the remote mounting make for reading the compressor map? It would seem to make not too much of one.
Old Oct 24, 2004 | 04:05 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
You have cooler exhaust gasses at the end of the exhaust pipe. The cooller gasses uses less space so you will have a smaller exhaust volume driving the turbine. That is the reson for using a smaller turbine housing at the back.
The compressor side of the turbo still needs to be the same size.
Old Oct 24, 2004 | 07:40 AM
89JYturbo's Avatar
Old Oct 24, 2004 | 10:40 AM
Guess i could have thought about it a little more and come up with that on my own lol.
thanks guys
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
