adding nitrous for next summer
Old Dec 5, 2004 | 02:27 AM
ll-84camaro-ll's Avatar
Car: 91 Z28
Transmission: 4l60e
ok guys i want to add nitrous for some added power by next summer. my question is if i just run lets say a 75 shot will it make a big difference and will my stock pistons and other internals be able to hold up to a 75hp increase without any damage?
Old Dec 5, 2004 | 07:49 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I have a 75hp dry shot of nitrous.
Works awesome. Went from a 14.3 sec in the 1/4 to 13.6(g-tech times).
I added a bigger fuel pump for safety.
The stock internals will hold it if you do it SAFELY!! AND SMARTLY!!
LB9GTA
Old Dec 6, 2004 | 05:08 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
You'll be fine. Don't use platinum plugs and retard the timing about 3*. Get a fuel pressure safety switch and a bottle heater. They are worth their weight in gold.
A 100 shot is a lot more fun. Pull another * of timing out for a total of 4* and run a step colder on the spark plugs. Remember to gap the plugs at 0.035" Do NOT the stock gap or larger, you run the risk of blowing out the spark and running into problems.
Old Dec 6, 2004 | 10:05 AM
Car: 91 Z28
Transmission: 4l60e
yea ive heard about not running platinum plugs. so looks like ill need a new set of plugs and ill have to retard the timing. and about fuel pressure if i run a 100 shot for added kicks would i need to adjust my fuel pressure? i have an adjustable fuel pressure regulator so its no big deal if it needs adj a little
Old Dec 6, 2004 | 09:21 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Hey, Freebird,
What plug did you use?
Did you use premo fuel(what octane)??
Did you use the 125 hp shot yet?
How much quicker in the 1/4 with the 25hp?
LB9GTA
Old Dec 7, 2004 | 06:19 AM
Free Bird's Avatar
Engine: 355
Axle/Gears: 4.11
I had a wet kit. I used the 50 and 75 shot w/ 93 octane, backed off timing, and stock autolite plugs. I went to 100 shot w/ less timing and it detonated. So changed to a colder plug and it ran great. Went from 13.4 at 103 to a 12.4 at 109mph.
Dyno'd 267rwhp and 356rwtq. On the jug
361rwhp and 551rwtq w/ the 100 shot. It hit well.
When I tried to spray 150 she backfired through the intake taking some pieces w/ her. It was my own stupidity (bad tune), but it didn't break anything major.
I got tire of going slow, so I built a real motor and put a direct port 200-600 on it. Separate fuel cell w/ C16 and a timing control in addition to the progressive controller. Best part is.......................you can't see it. Any of it.
Oh and the other question, I would always run a wet kit. But that's me. Bumping up the pressure isn't going to hurt, but the kit should supply enough fuel as long as it's set up right.
Old Dec 7, 2004 | 07:53 AM
Wayne's 383Iroc's Avatar
Car: 88 IROC
Engine: 383
I ran a 125 wet kit on my 350 and never had any trouble. I made sure it was on the rich side with a higher fule pressure setting. 46psi
Old Dec 7, 2004 | 09:30 AM
85_ZED28's Avatar
Car: '85 Z28
your rims are 16"?
Old Dec 7, 2004 | 11:19 AM
Car: 91 Z28
Transmission: 4l60e
yea my rims are 16" ZR1 wraped in 245/50 nitto tires
Ed1LE
Sep 30, 2018 09:14 AM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
aaron7
Sep 30, 2015 09:15 AM
