Need cam suggestions for new turbo 355 setup
Old Dec 7, 2004 | 10:44 PM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
355 with forged internals
TF 23* heads, springs good to .540 lift ( I have 1.6 roller rockers)
Planning the BBS single turbo at 12+ psi (probably 15 or so )
Supperrram intake
max power range probably 6200 rpm or so
4.10 gears with T56 tranny
have 24# injectors... might need more?
looking for a flat tappet cam
I have a Lingenfelter 213 Cam 224/234 .496/.520 112CL but Im not sure thats a good setup for boost.
Old Dec 7, 2004 | 11:31 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
If you use a roller block, which i dont see why you wouldnt, check out the bottom of this page
http://www.cmotorsports.com/engine/l...ft-design.html
Old Dec 9, 2004 | 06:53 PM
lock's Avatar
Car: 86 IROC-Z
How about this fine flat tappet bumpstick? Ill be running 1.6 rockers though, this shows 1.5 lift.
Part Number 12-404-4
Engine 1955-1998 Chevrolet
262ci-400ci
8cyl.
Grind Number CS 268AH-14
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.464 0.464
Duration At 0.006 Tappet Lift 268 276
Valve Timing At 0.006
Open Close
Intake 24 64
Exhaust 76 20
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Duration At 0.05 222 226
Lobe Lift 0.309 0.309
Lobe Separation 114
Old Dec 12, 2004 | 05:51 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
I am running a TPIS ZZ-9 camshaft. When i was looking for a cam i called up TPIS and told them i was building a turbo tpi engine, they said that the ZZ-9 would work great. The duration is supposed to work well with a turbo setup.
Street Lethal
Apr 30, 2019 12:14 PM
lt1z350
Aug 28, 2015 05:57 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
355tpipickup
Aug 13, 2015 07:35 AM
