Turbo plumbing
Old Dec 8, 2004 | 08:50 AM
IANTI's Avatar
Car: 88' IROC
Transmission: 5 speed
Turbo plumbing
I have a few questions about the plumbing of a single turbo setup.
-I know mandrel bends are a necessity but how big 2 1/2 inch or 2 and 1/4 inch?
-the exhaust from both headers are joined by a crossover pipe?
-Is there a lot of clearence issues present when using a 327 sbc and turbo?
Old Dec 9, 2004 | 01:45 AM
bottledbird68's Avatar
Car: 1 68 bird, 2 87 birds, a 92 bird...
Engine: carb'ed 305 in the 87, yuck...
Transmission: 700R4, for now....
1. I would go with at least 2 1/2" piping
2. Yes, both headers need to be connected with a crossover pipe before the turbo
3. All depends on what you have for options, what you want to keep for options, and, where you decide to mount the turbo...
Good luck
Old Dec 9, 2004 | 06:35 AM
IANTI's Avatar
Car: 88' IROC
I don't think that I am going to have air conditioning as an option if that is what you are inquiring prolly alternator and other necessities and the turbo will probably be located on the left front of the engine bay when looking from the front of the car. Also I will be replacing the stock 305 tbi to a possible 327 cid with tpi intake or something of similar origin.
more questions:
-Another question will I have a lot of clearance issues?
-Can a complete system be built without the car present for measure engine bay specs.?
Old Dec 10, 2004 | 12:15 AM
To answer the new questions:
1. Which side is your battery currently on? and, will it be staying there if it's in the way? Also, do you plan to keep the washer fluid bottle? We have no clearance issues in our car but the battery is in the hatch, no washer fluid, relocated the overflow, and there's no ac. It's really all in how you set it up, and, of course, in what size turbo you use...
2. This can be answered with a solid "No way in hell"
Old Dec 11, 2004 | 01:58 AM
83 Crossfire TA's Avatar
Why? For what most people end up doing crush bent is fine.
it depends on what you’re talking about, hot side or cold side, twin or single, what size, engine package…
For the most part they can be significantly smaller then what you’d make them NA, and if I was using crush bent pipe I’d probably choose a size ¼” bigger then I would with mandrel bent, but it’s not a necessity.
single- yes, most of the time, twins- not necessary but woudn’t hurt.
between what and what?
that depends on your design, what you’re willing to deal with…generally, yes if you’re make any attempt at optimizing things.
by someone very familiar with them, yes. I’ve built a few that were 90% done on an engine on a test stand and only left things like the final turbo flange angle on the header done on the car to get it just right.
OTOH, for 99% of the monkeys out there with a welder, good luck
Old Dec 11, 2004 | 12:29 PM
B&G CUSTOM TURB's Avatar
Hi
A friend told me I might want to come over here and chime in. This is my first post on the board and hope to have many many more.
Click me for turbo headers
Heres a sneak peek.
Old Dec 11, 2004 | 04:51 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
holly crap bat man!!!! Much cleaner than the "other guy" that post here alot. I'd be willing to test fit them on a g-body for you. Of course you would have to just "give" me a set for all my hard work. Defefinately keep us posted.
Old Dec 11, 2004 | 05:30 PM
83BlackBeauty's Avatar
Car: 83 Trans Am
Engine: 5.7 (350) TPI
Transmission: soon to be 700r4
Axle/Gears: 9-bolt rear. gears? hell if i know
let us all know when you have the 82-92 camaro/firebird headers done, i am positive you could get a huge group order!
Old Dec 12, 2004 | 11:02 AM
HI,
I build as you order. You can check my rep on turbo mustangs. Been building and selling for a year now.
Outright I will sell these for 600.00 group buy of 5 or more get you 75 off.
These are 5/16 head flanges. 1/2 turbo mount.
If you want all 1/2 flanges ad 50.00.
So......
525.00 for a group buy of 5 or more.
wastagate flange add 30.00.
1/2 head flanges add 50.00.
Downpipes
ONLY ON GROUP PURCHASE HEADERS
Down pipe 3 inch for masterpower that goes down beside tranny. with a v-band on both ends. 175.00
wastegate flange on down pipe 30.00
o2 sensor mount 15.00 each installed.
Thanks,
Brian
WWW.BGTURBO.COM
FORGOT TO MENTION 100% TIG WELDED
Old May 17, 2005 | 03:34 AM
JekyllandHyde's Avatar
Car: 87 Trans Am GTA
err, these require removing the smog pump right? If not, I can easily just weld in AIR tubes to make the system functional.
ZZ3Astro
Aug 13, 2019 12:57 AM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
