Installation manual for Vortech?
Car: 89 IROC
Engine: 350 CI Tuned Port
Transmission: Automatic
Axle/Gears: 3:45
I just purchased a never installed complete vortech kit for a TPI. The kit is a few years old, its the B trim compressor. Does anyone have an installation manual for this or one similar? I would be happy to reimburse you for time and copying.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Installation manual for Vortech?
Here is a link to the manual:
http://www.vortechsuperchargers.com/...s/4gf218im.pdf
Theres a few things I'd like to add:
1) Take the oil line supplied and sell it. Buy a braided line and some adapters and run the oil feed line to the back of the motor.
2) Don't splice up your fuel feed line. Sell the booster pump. Instead, replace your in-tank pump with a high pressure walbro unit. 255lph or better. Sell the vortech supplied pump.
If you decide down the road, you want to get into prom tuning and such, we're here to help.
-- Joe
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Re: Re: Installation manual for Vortech?
Originally posted by BLWN1
Nothing a pulley change won't help...
Been there, done that, bought an S-trim. Now i'm thinking Y trim.
-- Joe
I just saw a Y trim on www.nmraracing.com/forums not sure what discharge you need. Are you running Vortech brackets? How much for you S trim? I need to find some brackets soon I guess..... I don't know much about the B but remember a few cars of old running 10's, mustangs though...
Car: 89 IROC
Axle/Gears: 3:45
Thanks for the link. That was just what I wanted. I was already going the Walbro route, My stock pump is having trouble keeping up now. I will definitely be burning chips as there is really not much left of my stock motor. I think I will be Ok with 5 or 6 lbs. If I need more I will just use my liquid intercooler. I would guess I am in the upper 200 N/A at The rear wheels right now as it will make short work of my LT1 corvette. Geesh I hope I it doesnt run 10s. The rest of my drivetrain will come apart for sure!
Heres my setup:
89 IROC-Z TPI
All the free and cheap mods you can think of
355 Cubic inch 9.5 to 1 compression
Fully ported corvette aluminum heads w roller rockers
214/224 duration camshaft
Fully ported stock base and plenum
SLP runners
Edelbrock headers
Hooker Catback
700 R4 with shift kit
2200 RPM stall converter
3:42 Posi Rear
A tickle of Go Juice
Any suggestions or guesses?
Thanks For all the help.
Heres my setup:
89 IROC-Z TPI
SLP runners
Edelbrock headers
Hooker Catback
3:42 Posi Rear
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Heres my setup:
89 IROC-Z TPI
SLP runners
Edelbrock headers
Hooker Catback
3:42 Posi Rear
Heres my setup:
89 IROC-Z TPI
SLP runners
Edelbrock headers
Hooker Catback
3:42 Posi Rear
Sounds like a decent setup you got there. What are you running for heads?
With that compression, i'd start off around 20d advance and see where you go from there. It's better to lock the timing in around 3k, then go up 2d after max torque than it is to go all the way up and retard underboost. (spikes EGT!)
-- Joe
Car: 89 IROC
Axle/Gears: 3:45
I am running the D port corvette heads with Street Flo style valves and some pretty extensive porting. I am already running the 24 lb LT1 injectors. You dont think they will keep up? The NOS system is a Wet plate system so the injectors arent an issue as far as that goes. You lost me a bit. What is $60 in a 730/749?
Showing my ignorance
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
The 24# injectors IMO won't be enough. My old setup was around 8.96:1 compression with 12psi and 36# injectors were not enough.
Those vette heads should work nice with the boost.
-- Joe
Car: 89 IROC
Axle/Gears: 3:45
Bang a hole in the side of the oilpan and then thread it for the return line? Does this actually work and not leak? I can think of a whole lot better ways to do this. They are all more work so I might do it this way if it works better than it sounds. Experiences?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
sucks huh?
-- Joe
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
