Injector size for 383 w/14lb boost
Old Dec 19, 2004 | 05:48 PM
AC's Avatar
AC
Car: Used to drive a camaro
I'll give some insight then ask:
TPIS Bigmouth Intake
SLP Siamesed runners
Eagle forged 383 rotating assembly
Dart Iron Eagle 72cc / 230cc heads
4bolt 91 block
Holley 58mm throttle body
Comp cams custom grind
Harland sharp roller rockers.
I was planning on having the stock fuel rails opened up but am still battling injector size. I will lose the ATI FMU. I have a Sy/Ty ecm and am going to repin and have all the puter tools I need to read / burn my proms. Any insight to injector size would be great...while I'm asking would 1-3/4 header primaries feeding a true 2-1/2 dual exhaust be a big enough exhaust system?
Old Dec 19, 2004 | 06:00 PM
biggtime's Avatar
50's at the least but then your gonna need to put some drivers in that ecm for bigger ones. We can't guess on your output as you listed no camshaft spes. I had 55's and they went static at 600 at the crank. got 85's now but I use a DFI
Old Dec 19, 2004 | 07:15 PM
AC's Avatar
AC
biggtime,
55 went flat huh...hmm. I've seen 55's and 60's high impedence for sale. Are there ecm mods/patches for the 749 and %58 code?
toronto formula
Nov 10, 2015 06:17 AM
bamaboy0323
Sep 3, 2015 06:07 AM
86White_T/A305
Aug 17, 2015 12:16 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
knight72
Aug 10, 2015 09:32 PM
