Can i run a carburetorated turbo setup?
I was just wondering because i never see anyone running turbo with a carb. Also if this is possible, for this setup what would you recommend, a 383 stroker in a 3rd gen (obviously) 8.0:1 compression twin turbo or single turbo? I know there's a lot more to it than that but i'm just kind of tossing around ideas. thanks for the replies.
Transmission: 4L80E/4L80E
Considering when carbs, turbos, and EFI came into being, the obvious answer is "yes" (the original turbo Regal was a q-jet).
However, this is a topic for the Power Adder forum, rather than carb.
Car: I
Engine: Taunt
Transmission: Mustangs
There is a whole board over at turbomustangs.com for turbo carb setups (don't fret, there's more than just ford people over there). Lots of good info to be found there. Here's a great example of what's possible (just pretend it's a f-body):
http://www.turbomustangs.com/feature...adblowthru.htm
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Aug 13, 2015 08:28 PM
