Extremely Stupid question
Old Apr 13, 2005 | 08:52 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Axle/Gears: Limited 9 bolt, 3.45
Okay 89' TPI 305 with a 5spd. (borg warner) and 9bolt(borg warner) with 3.45's.
I wanna make this car well fast. She is completely stock, will the tranny hold up to lets say a 125shot of nitrous? I know the motor will take it but will the driveline? I doubt it since the LB9 can drop it out of the bellhousing in stock form but i want opinions.
If i get a system it will be a NOS wet TPI system, nothing fancy, just for track use, thanks.
If the Nitrous produces to much torque, would a turbo fair the tranny better?
Old Apr 15, 2005 | 09:07 PM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
Let me restate this, will a 89' borg warner 5spd wc hold nitrous? How much
Old Apr 15, 2005 | 10:10 PM
Got TPI?'s Avatar
Car: 1992 RS / 1986 Iroc
Engine: 350 Vortec / 305 TPI
Transmission: T5 / 700r4 on it's last leg
You mean like more than once?
I wouldn't throw more than 300ft/lbs of torque through a stock WC T5 trans, hell I think it was rated at 270 with the non WC rated at 230.
Old Apr 24, 2005 | 12:37 AM
rocluvr0013's Avatar
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Theres a reason they never put 5 speed's behind 350's... they cant handle torque...
Old Apr 24, 2005 | 01:52 AM
92-Formula's Avatar
Just don't spray in 1st gear and you'll be fine.
Old Apr 24, 2005 | 01:19 PM
Steven89Iroc's Avatar
Re: Extremely Stupid question
If you know it's an extremely stupid question, then don't ask it.
Old Apr 24, 2005 | 03:51 PM
Truckboy's Avatar
uh yeah whatever the IROC guy said
Old Apr 24, 2005 | 04:58 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
spray it, keep it around 100 wet shot, if it wheel hops fix the suspension, don't keep allowing it to wheel hop over and over, that will kill the tranny and/or the differential.
like this ->>>> here
Old Apr 24, 2005 | 05:17 PM
Engine: 350 tpi
Ive never heard that before B4cTom...? I thought that the only thing wheel hop would kill is 60 ft times?
How would MORE traction Prevent damage to the tranny and diff?
I would think that the best way to save your tranny would be to wait til later in the run to spray, however this is based on my limited knowledge and track time so dont quote me or anything...
my
Old Apr 24, 2005 | 06:24 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
just don't power shift. I blew third gear (took the teeth right off the gear) when I had mine another friend took 3rd out on his firebird. I know a couple guys with 5.0 stangs that did the same. there are so many parts that break on the t-5 it's hard to say when to use the shot and when not too.
I guess just keep the wheel hop down like was already stated (shock loads the whole drive train ... like dumping the clutch and slamming gears but quicker)
Old Apr 24, 2005 | 07:12 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
my
The loading unloading of the suspension and drivetrain has a jackhammer effect. This kills the new GTO rears and even C4 vettes would suffer from this issue.
When I lived out in Cali I had about 12 or 13 broken thirdgen diffs piled on the side of the house and 3 trannys. most of those broke in wheelhop situations.
One broke when I was frying them across a parking lot and drove over the speed bump, and one broke when I drove off a curb hauling ***.
A couple were broken during a high RPM clutch dumps. The others were broken during power shifts.
When I bought my Herb Adams solid control arms I quit wheel hopping and would simply "flat spin", which is alot less dramatic and less harmful.
I am wondering if you understand what I mean by wheel hop. If you have ever driven a car with severe wheel hop, you wouldn't even try to burn out again until you fixed the problem. I once saw a 3rd gen firebird wheelhop so badly once that it shattered the rear hatch glass.
Old Apr 25, 2005 | 09:21 AM
Mcdamit's Avatar
Car: 89' Iroc-Z G92
Engine: TPI 305 G92
i know what you mean by that thanks, im going to look into a tremac
Old Apr 25, 2005 | 11:39 AM
Engine: 350 tpi
Gotcha b4ctom that makes sense, a flat spin would do much less damage then wheel hoppin'
Cleotiz
Jan 6, 2018 08:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
