Pratical Turbo TPI limit
Old Apr 17, 2005 | 11:23 PM
wanarace's Avatar
Car: 1986 Cutlass
Transmission: 200-4R
What is the practical HP limit for a stock TPI intake in a turbo application. Forget about fuel and ECM. Just wondering at level the intake becomes a huge restriction.
I am building a turbo TPI 383 for torque, as an everyday driver. Turbos will most likely be HY35 from the auto dodge diesel. I can get the HY35s for free. I am shooting for 500HP and the crankshaft.
Steve
Old Apr 18, 2005 | 01:17 AM
/\/3\/\/l8l3's Avatar
[deleted by mod]
Old Apr 18, 2005 | 07:44 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Preston Smith had one on his turbo'd drag car, in the 9's from what I remember... Stock TPI is VERY different from a modified TPI (58mm tb, hogged plenum, cast & ported runners/TPI base, etc). I'd have to guess you could squeeze out 600+ hp, but even at that point, a different intake design would get you more hp (HSR, MiniRam, LT1, SinglePlane). Build it w/ the TPI, and as you get bored with the HP, change the intake down the road. No need to do it all at once.
Old Apr 18, 2005 | 08:35 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
like Andris said,
Preston has a Stock lower base. (extrudhoned)
AS&M runners,AS&M 58mm TB and Ported plenum.
Trickflow G2 - 2.02” int. (275 CFM) – 1.6” exh. (210 cfm)
10.92@126 on 93 and 16psi of boost.
9.92@136 on 117 gas and 25lbs of boost.
Forcing that much boost (25psi) is a TON. He oculd deff get the same times with less boost if he had a better intake setup.
Old Apr 18, 2005 | 08:11 PM
WHy would you use TPI? It isn't the best way to make power
Old Apr 18, 2005 | 08:38 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I am sure it is what he has already. he needs to start with something. when time and money allows you upgrade
Old Apr 18, 2005 | 08:55 PM
wanarace's Avatar
Car: 1986 Cutlass
Well I don't have a TPI setup yet and I am fully aware of their breathing limitations. But what a TPI does very well is torque. I could easily go with a blow through carb and make way more horsepower then a TPI could ever come close to, but HP is not my only goal. I may still go with a carb setup. I get my Wideband O2 sensor in a few days
My main goal is drivability, and some sort of gas mileage. I have 91 Cavalier, so I am no stranger to the 730 ECM's and tuning shouldn't be too much of a problem.
I just wanted to make sure the stock TPI didn't completely die at a certain level, or if there were any serious fuel distribution problems under boost.
Thanks again.
Steve
Old Apr 18, 2005 | 09:17 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
May not be the best way but you cant look deny the fact that you can run 9's with a slightly modded one. but for the $800 invested in Prestons (400something for the AS&M runners, and $400ish for the extrude hone work) you can pick up a HSR/LT1/maybe used SR.)
Old Apr 18, 2005 | 09:35 PM
1bdbrd's Avatar
Car: 1991 Trans Am
i would suggest against a TPI intake. a turbo v8 (or any turbo motor for that matter) will make a TON of torque. a 383 is a very torquey motor NA, then you add a power adder that makes lots of torque on top of that and you are gonna have more than enough. i say look into a different kinda of intake. there comes a time when too much torque makes a street car undriveable.
like always, thats my opinion anyway.
Old Apr 21, 2005 | 09:17 AM
Z RATED IROC's Avatar
Car: 89 Camaro
I'd say it totally depends on your budget and ultimate Power goals.
Last weekend I saw an 87 TA, bone stock 5.7 TPI with a 6 speed put down something like 340 HP and WELL over 400 Ft lbs to the wheels using an SYS turbo kit.
This was on only 5 Pounds of boost! Think about when he gets the tuning complete, Adds an inter-cooler or Meth. Injection and turns up the boost to 10#s. AWSOME! I would have little doubt that he will see 400+ RWHP and save allot of money as a bonus!
The forced induction will not really change the rpms that the TPI motor will make its power. It just really boosts the curve to the next level.
As a minimum rule. If you are doing an engine overhaul in conjunction with your F/I install, stay with a stock TPI cam or maybe upgrade to one with a little bit extra lift and exhaust duration. Get some forged pistons and upgrade your Connecting rods. Focus on making power below 5000 rpm.
Dave
MustangBeater20
Oct 29, 2022 09:20 PM
Terrell351
Jun 13, 2021 01:13 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
