Timing retard with ATI & intercooler
Old Jun 9, 2005 | 01:41 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Folks that have ATI intercooled blowers. Does ATI give you a device like a BTM to retard ignition timing, or do you run normal stock timing and just add fuel via FMU ?
Just trying to compare how ATI does it, vs Vortech, vs OEM.
-- Joe
Old Jun 9, 2005 | 03:09 PM
Lo-tec's Avatar
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
No timing retard, just the FMU.
Old Jun 9, 2005 | 03:20 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thats really interesting.
OEM stuff retards timing, and vortech uses a BTM.
Retarding timing under boost spikes cylinder temperature. I'm wondering if ATI has the right approach. Since i'm intercooled, I'm thinking of ramping out timing to max around 3200rpm and leaving it there.
-- Joe
Old Jun 9, 2005 | 04:24 PM
CRZYTRN-92Z28's Avatar
Car: 1992 Z28
Engine: 350 L98 w/ D-1SC
Transmission: POS 700-R4
Those air to air intercoolers allow you to run full timing all day long. ATI has got some quality parts. Btw Im still using the FMU
Old Jun 9, 2005 | 05:02 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Thats why I put an intercooler in for this year.
In regards to the FMU, I ditched that a while back. I like being able to tune fuel, rather than assuming the fuel requirements will be linear with boost.
-- Joe
Old Jun 9, 2005 | 07:27 PM
Lo-tec's Avatar
-- Joe [/B]
FMU works, but tuning it yourself will allow you to get the most out of your combo. I've never done a WBO2 on one, but I'm sure they err on the safe side with the FMU.
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
MoJoe
Sep 15, 2015 12:50 AM
bamaboy0323
Sep 3, 2015 06:07 AM
