Methanol Injection System
Old Jun 15, 2005 | 08:08 PM
transporter's Avatar
Car: 92 Z28
Engine: 305 TPI, Edelbrock headers, 3in Flowmaster exhaust
I got a new Summit Racing catalog and under new products I saw this. Anyone with experience with this? Worth the money or not?
http://store.summitracing.com/defaul...=egnsearch.asp
Old Jun 15, 2005 | 08:54 PM
blown3rdgen's Avatar
That is the kit I have on my car (Snow Performance). I am happy with the quality of parts used and the performance/protection since I don't use an intercooler. I have the one with the progressive controller.
Matt
Old Jun 15, 2005 | 11:43 PM
Raiden's Avatar
I have a paxton sn2000 with the VR4 upgrade impeller. I purchased a shur flow pump for 50 bucks. Here is a link to a DIY water injection. http://members.***.net/stevemonroe/AlcoholInjMod.html
Old Jun 17, 2005 | 03:19 AM
CrazyHawaiian's Avatar
Car: too many ...
I dont have direct experience on my car, but I do have a friend with a 10 sec street car and he is running a similar Methanol Injection system. He runs a mix of Water and Methanol (40/60) in a seperate fuel cell. His kit is progressive, it uses input from a pressure sensor and the voltage output of the 1st injector. Depending on the readings from those two sources, it will begin injecting the mixture, and then also inject more (via high pressure nozzle) when the boost and injector voltage rises (increases voltage to the pump). Its a pretty slick setup and it allows him to hit 2 bar of boost (28psi) with 92 octane in the regular tank. I plan to use a similar setup when I get further along with my F/I project.
Old Jun 17, 2005 | 09:55 AM
Raiden's Avatar
right now, I have my water injection connected to a hobbs switch so it will turn on at 6-7psi. Next year, I plan on purchasing the PAC controler unit which will titrate the voltage to the water pump in relation to teh amount of boost, so at full boost you get full power to teh pump, or where you want to be with the water injection unit.
http://www.alkycontrol.com/
Old Jun 18, 2005 | 09:54 PM
AJT86's Avatar
Car: 87 Buick Grand National
Engine: 3.8 SFI Intercooled Turbo
Transmission: 200R4 3000 Stall
see what julio at alky controll can do for you- hes a great guy to deal with. his kits are beautiful
Old Jun 22, 2005 | 09:37 AM
Nitro Dave's Avatar
Engine: 94Z28
This thread is geat.I have been kicking around the idea of building these kits but was not real sure how many people actually used them.Maybe Ill look further into it.
Dave
Old Jul 10, 2005 | 11:42 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i have the smc kit .
Old Jul 11, 2005 | 12:45 PM
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
anyone have a good cheap source for methanol?
Old Jul 11, 2005 | 06:20 PM
local speed shop= 3.18 gal
Windshield washer fluid rated at -20* contains meth and will work = $1.25gal at local parts store
Old Jul 13, 2005 | 12:54 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
what about the sope and other stuff in washer fluided
Old Jul 13, 2005 | 09:35 PM
no problem with soap-
Actually check around it is fairly common. The July 05 popular hot rodding did a snow kit install and used "peak" windshield washer fluid.
Matt
Old Jul 14, 2005 | 10:28 AM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
For those who haven't been there yet, here is a link to the Snow Performance website. Lots of good info on meth injection in the forum and of course all the details on their product lineup as well.
Old Jul 20, 2005 | 10:15 AM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
Matt
I have heard of the detergents clogging up small nozzles after some amount of time. What happens is the water/methanol evaporates too near to the nozzle, the detergents dont evaporate and get deposited right at the nozzle outlet.
Clogged Nozzle = not injecting when you think it is = boom.
this can be prevented with maintenance, but just something to think about.
Old Jul 30, 2005 | 02:40 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The detergents have nothing to do with it. Think about it. Detergents, clogging, it isn't going to happen. The clogging is caused by the minerals on non distilled water.
By rights you should be using distilled water mxed with methanol.
you want to use -40 "winter" windshield washer fluid.
its high in Methanol and low in detergents as compared to the "summer" formula.
Old Jul 30, 2005 | 10:51 AM
Jetmeck's Avatar
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
How large of a tank would be required for the extra ww fluid, yes I realize the harder you drive the more you will use, but give me an idea.....thx
Old Jul 30, 2005 | 01:23 PM
Car: 82 Trans am
The recommended meth/water to fuel ratio varies depending on several factors, but can go as high as 15% of your fuel amount. Considering thirdgens have a 16(?) gal. tank, that works out to 2.4 gal. of meth/water mix. Now considering that most of the time you drive, you will not be injecting. So I'd take a stab and say that anything over 1.5g would be overkill. Just fill it when you fill your gas tank. Now on a drag only car, that could be different, but just keep a better eye on it.
Old Aug 7, 2005 | 05:22 PM
KintaroOe's Avatar
Car: '91 bird '87 Z28 '86 T/A
Engine: LO3 LG4(ls1 in works) 350
Transmission: 700R in all
Axle/Gears: wimpy 10 bolts
you could possibly use the windshield washer resevior as your tank by plumbing a line in the bottle. just n idea for a diy job
Old Aug 8, 2005 | 10:30 PM
Raiden's Avatar
That's what I use, works great. I do have to refill it if I'm getting into boost a lot.
Old Aug 13, 2005 | 09:27 PM
KnightWarrior's Avatar
Car: 1985 Camaro Z-28
Engine: 305 V-8 4BBL (H) Supercharged
Axle/Gears: 3.42 Eaton Posi
Is methanol safe for the catalytic convertor or will it ruin it?
Old Aug 13, 2005 | 10:18 PM
F-BIRD'88's Avatar
Methanol will not effect the cat. It is a clean burning fuel.
Much less soot (carbon) than gasoline.
Old Aug 14, 2005 | 12:08 PM
That's great to hear, because I want to run this system with my new WEIAND blower to prevent detonation. I like te idea of using a stock windsield tank to hold the juice and keep a neat compartment. I'll have to get a new one. I removed mine years ago.
Old Aug 25, 2005 | 09:02 PM
Flatlne's Avatar
Car: 1990 Iroc,2002 C5 10 sec,1948 chop/blown chev pickup,1990 vette 9sec project
Call Doug or Chris at east coast supercharging they can answer any and all ?
Old Aug 26, 2005 | 03:53 PM
skunkIROC's Avatar
Car: 88 IROC
Transmission: th350 w/ b&m shift kit
so is this really only for engines receiving boost, be it through turbo/ super charger?
basically, would it make any sense to throw this on a mostly stock engine? or would that be pointless?
Old Aug 26, 2005 | 04:01 PM
79vette's Avatar
Car: 1979 Corvette
Engine: 355, TFS heads, comp 270H cam, 10.5 comp.
Transmission: 700r4/ 3:55 posi/ 2500 stall
It is pointless to put it on a stock N/A engine but for a Very high compression (1:12 or higher) N/A engine it will be helpful to use if your using pumpgas such as 93 octane. It will basically raise the octane of the fuel mixture and fight detonation. So if you got a race gas only motor and need to run on regular pump gas this might be helpful.
Old Aug 26, 2005 | 07:22 PM
skunkIROC's Avatar
Car: 88 IROC
so its more of a prevention concept than a power booster?
Old Aug 27, 2005 | 12:36 AM
79vette's Avatar
Car: 1979 Corvette
It will act as a intercooler, thus a power adder, for boosted aplications but on a N/A motor when the air charge is already the ambient air temp it wont help much in cooling down the air going into the motor. It is mainly to prevent detonation on a N/A motor.
Old Aug 27, 2005 | 02:37 AM
rooster433's Avatar
I'm thinking about putting alcohol on my own car again. Last friday I dyno tuned a mustang wtih a anderson mr. freeze kit.
The Mr. Freeze kit doesn't use a pump but boost pressure to push water back up into the intake (pre-blower) via small hose barb. It ws a really cheezy system to say the least. The guy even used washer fluid
Even still the car picked up 50rwhp!!
Old Aug 27, 2005 | 05:25 PM
skunkIROC's Avatar
Car: 88 IROC
any idea what it picked up at the crank?
Old Aug 28, 2005 | 03:26 AM
skunkIROC's Avatar
Car: 88 IROC
no?
Old Sep 2, 2005 | 01:43 PM
jack_sparrow's Avatar
Car: 1985 Camaro
Engine: 350 bored 40 over
Transmission: 700-R4 Race prepped
Well considering, correct me if I'm wrong guys, but you lose 23% of power through parasitic loss of the drivetrain. So 50 * 1.23 = 61.5hp gain at the crank is what I get.
Brett
Old Sep 3, 2005 | 01:31 AM
skunkIROC's Avatar
Car: 88 IROC
seems apparent that if you have a boosted engine, methanol injection is worth it.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
racereese
Oct 10, 2015 09:39 PM
customblackbird
Oct 1, 2015 04:30 PM
aharvel50
Sep 21, 2015 07:31 PM
