Turbo or 8-71
Old Jun 26, 2005 | 03:38 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Turbo or 8-71
So we are finished with paint and int, so its engine time. We are
going turbo or supercharger and would like the pros and cons of these 2 setups. My main question is how long will a weiand 8-71
last on a weekend street/race car. Is it rebuildable if it breaks?
Any opinions will be appreciated.
Edit: This will be a 400 smallblock build.
Old Jun 26, 2005 | 05:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Do you have any idea how big an 8-71 is for a street car?
Old Jun 26, 2005 | 05:31 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
kinda like this
Id say go Turbo. but Im biased.
Old Jun 26, 2005 | 05:34 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Id say Twin or Single Turbo..
Old Jun 26, 2005 | 05:57 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Well it will be more race than street but I would like to cruise it through town.
I'm leaning towards turbo because it won't stick out of the hood,
but I think a blower would be more impressive at the car shows.
I'm lookin to get some trophies to help promote my body shop.
Old Jun 26, 2005 | 06:16 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
to me, nothing looks cooler than popping the hood and being greeted by a bunch of tubes that have been powder coated to coordinate with the car (intake side) and polished stainless tubes to compliment them colors (exhaust side)
Old Jun 26, 2005 | 08:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Even still, a 4-71 would probably be more than enough. Many all-out race cars still use only a 6-71, not an 8-71.
Old Jun 26, 2005 | 08:41 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
You are correct the 6-71 is the one I have been pondering.
Is the 4-71 the single carb version.
Old Jun 26, 2005 | 08:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Any of them can be single or multiple carbed, it just requires changing the top plate.
Old Jun 26, 2005 | 08:53 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Thanks for the info. 2 more questions can you run the engine without a belt to the supercharger, and we saw a blower at a show and it looked like it did not have carbs. What was it using?
Old Jun 26, 2005 | 08:58 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If it didn't have a carb on top, it would have some sort of multi-port fuel injection. On a street car this is probably the way to go since you can eliminate some of the height of the carb when you replace it with a throttle body.
The car won't run without the blower turning, unless there's some sort of bypass valve installed, which would be more of a "limp-home" system than anything you'd actually want to drive.
Old Jun 26, 2005 | 10:56 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Do turbos cause extreme underhood heat? Still would like some more input. THANKS
Old Jun 29, 2005 | 04:09 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
I have heard of some horror stories of turbos getting extremly hot with the hood closed, although you can wrap them and do some things to cut down on heat, it will still get hot from the turbo
Old Jun 29, 2005 | 06:25 PM
dj's B4C's Avatar
Car: 1992 B4C/1LE/L98///1992 Z28/Heritage Edition?/L98 white with Black stripes///1992 Z28 Convertible Heritage Edition, L03 with RMT, white w/Red Stripes///1992 RS, Heritage Edition, white with red stripes
Engine: L98 x 2, L03, V6
Transmission: 4L60 x 2, 5 Speed x 2
Not true. Just last week the blower on my 65 Chevelle locked up at work. I pulled the belt and drove it home. Only problem was total lack of power because you can't get a lot of air through a supercharger that is not turning!
Turns out one of the rotors started eating itself up. Maybe caused by over tightening one of the mounting bolts.
Old Jun 30, 2005 | 02:35 AM
83 Crossfire TA's Avatar
Without a belt it will freewheel, if it’s not locked up it will actually accelerate with increased airflow and even make a blower wine like it’s still working.
Some setups used a mechanical injector, usually a thin, flat plate mounted between the scoop and the blower. Kinsler and a few others have made these setups work with efi which is pretty freaking cool.
Unless you’re really good at packaging the blower will probably be less of a hassle to maintain and drive on the road, although turbos have their own coolness factor… If it’s a showpiece there isn’t much more attention grabbing then a big, detailed blower poking through the hood, and that would give tons of opportunities to show off your skills, more so then a snakes nest of plumbing under the hood (this is coming from someone that in most cases prefers turbos)
Old Jun 30, 2005 | 01:58 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
If you ask me, roots blowers are all looks. They arent that good. And you see them all over. When you have a turbo on a V-8, alot of poeple are impressed. I'd would rather see a turbo thirdgen than a blown third gen. Just my .2
Old Jul 1, 2005 | 12:27 AM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
This is what worries me about turbos i'm afraid it would mess up my paint.
Old Jul 1, 2005 | 12:28 AM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Back to an earlier question is it rebuildable or are you just screwed if it breaks?
Old Jul 1, 2005 | 12:43 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They can usually be rebuilt unless the case itself gets scored.
Old Jul 1, 2005 | 01:10 AM
I think that around here people are a lot more interested in seeing turbos, but the fact is that in general, nothing stops people like a big honking blower sticking through the hood. The blower attracts attention no matter what you do, and will get people to stop and look, where people have to stop and look before they see the turbo setup.
Old Jul 2, 2005 | 06:43 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
i would much rather see a blower sticking through the hood, but the only thing that wories me is that with thirdgens the motor sits at a slight angle, i dont think that would look right.
could u just order 2 right/left side mounts to make it sit evenly in the car???
Old Jul 2, 2005 | 09:12 PM
mw66nova's Avatar
Engine: 7.0L
maybe you have retarded mounts, but mine sits just fine in the bay. sounds like you may have a worn out rubber mount on one side.
Old Jul 3, 2005 | 03:23 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
no everything is new, i heard it was normal for it to lean slightly to the passenger side
https://www.thirdgen.org/techbb2/sho...ight=hole+hood
scroll down to the camaro with the hole in the hood
Old Jul 3, 2005 | 04:43 PM
mw66nova's Avatar
Engine: 7.0L
just remembered, i'm running moroso solid mounts. mine sits right in the middle.
Old Jul 4, 2005 | 06:33 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
More questions, At what point do turbos and blowers start making boost? What is better for an 1/8 mile car? What makes more torque?
Old Jul 6, 2005 | 04:26 PM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Anybody? Come on I'm a bodyman not an engine guy so any help would be great!
Old Jul 7, 2005 | 01:50 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
a blower normly gets into boost sooner but with the rite converter and useing a T-brake you could have lots of boost at the line.
A blower "should" be ezer to set up...
I have a little turbo on my car,... just got it running tonite
Old Jul 8, 2005 | 02:41 AM
A properly built positive displacement blower will have boost proportionate to throttle position and load, so you could just about have full boost at any rpm assuming you give it enough throttle. A turbo needs sufficient exhaust gas to spool the turbo and enough time for that exhaust gas to overcome it’s inertia, the faster the turbo is set up to spool, the sooner/worse the restriction the turbine ends up being.
Old Jul 16, 2005 | 02:13 AM
Muirner's Avatar
Car: 89 Camaro RS
Engine: 86 Monty 305 .030 over
BLOWERS! those look way hotter in my opinion. That is the way i'd go if i had the $$
Muirner
Old Jul 18, 2005 | 06:52 PM
Motor City Mike's Avatar
Car: '82 Trans Am
Engine: Blown 540 BBC
Transmission: TH475
Axle/Gears: Dana 60, 4.10 w/spool
I really like my roots blown big block:
Instant boost and tire frying torque right at the hit of the throttle. Very easy to access the spark plugs (and other important things). Also easy to set-up, tune, and no underhood heat problems.
Old Jul 19, 2005 | 07:42 PM
Muirner's Avatar
Car: 89 Camaro RS
^^^^^^^^^ That is beautiful ^^^^^^^^^
Muirner
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
