got bored so I thought I'd toss up some turbo pics of mine
Old Aug 1, 2005 | 04:16 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Just figured I'd pop some up ....its to pretty to leave in a box
...this one is how I have to modify the turbo header to keep the smogg pump . I have to cut off the wastegate pipe and , weld it to the other header were I made the big read mark ( photostudio sux ...so be nice )
Have a nice day
Old Aug 1, 2005 | 04:29 PM
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
Is that a 62-1? What size exhaust housing?
Old Aug 2, 2005 | 12:58 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Yes it is a 62-1 . Ummmmm not sure on the exhaust size though It's the 650 hp kit from BBS turbo . Still learning stuff about it all . Maybe you can tell me now what the exhaust houseing size is LOL
Old Aug 2, 2005 | 01:20 PM
browncamaroz28's Avatar
Car: 1982 Camaro Z28
Engine: electric
Transmission: powerglide
Axle/Gears: 10 bolt
Re: got bored so I thought I'd toss up some turbo pics of mine
please don't put the wastegate there..... i'll explain why.... if you put it there you are letting pressure out on one side before they combine, this will cause a backflow of exhaust and also put more pressure on one bank of cylinders, bbs put it there for a reason.... please reconsider that by possibly putting it on the other side of the original pipe.
Have a nice day
Old Aug 3, 2005 | 01:52 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Edgardo suggected it to me in an email to put it on the other header pipe like that . Thats why he told me to put it in the part were the 4 pipes converge on the passenger side header. I would love to keep it on the drivers side but the smogg pump is in the way and I have to keep all the emmisions stuff. So let me see if I understand you .
You think that this will create reversion in the exhaust ? What if the inlet of the wastegate was pointed slightly away from the flow . As to only let the full exhaust preasure effect it's operation. Kinda how I got it drawn ( horribly I know ) pointing upwards a bit.
Thanx alot man . I appreciate the heads up BTW .
Old Aug 5, 2005 | 12:57 AM
Engine: electric
Axle/Gears: 10 bolt
well i guess if you have to do it then you should point it down as to help with flow through that bank of cylinders....
Old Aug 5, 2005 | 03:07 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
thanks man !
Street Lethal
Apr 30, 2019 12:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
TMoNeE
Northern California
Aug 24, 2015 06:11 PM
NinjaNife
Aug 23, 2015 11:49 AM
