Procharger Noise
Old Aug 4, 2005 | 11:44 PM
Treys_IROC's Avatar
Car: '89 Camaro
Engine: Blown 5.7L TPI
Procharger Noise
Ok, this one has me a bit worried, i just got my procharger on my camaro but now the actual procharger head unit has a sort of clattering sound mixed with a whine at idle, it sounds fine once you get going but at idle it just is weird
Now granted i dont know much about blowers, but this doesnt sound very good.
Thanks for any input,
Trey
Old Aug 5, 2005 | 07:04 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
It's normal for the procharger. Mine does the same thing and others I'm sure will respond that they have the same sounds.
Old Aug 5, 2005 | 08:57 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
The engine speed accelerates at every combustion and slows down between them, this is normal and not anythin that you normally notice.
Without load on the gears in the supercharger this uneven motion will create a 'clattering' sound.
Once the compressor wheel starts consuming power and the gearbox is under load that sound will go away.
Old Aug 5, 2005 | 02:03 PM
GreenChevelleSS's Avatar
Car: 1970 Chevelle SS 396
Engine: 414ci Big Block Chevy
Transmission: Muncie Turbo Hydromatic 400
Thanks it had us worried..
Old Aug 5, 2005 | 03:44 PM
Treys_IROC's Avatar
Car: '89 Camaro
Man, i'm very glad to hear that, almost gave myself a stomach ulcer from worrying...LOL
Thanks alot,
Trey
Old Aug 15, 2005 | 07:39 PM
kokamo's Avatar
Car: 73' Nova~~~TPI Powered
Engine: 283 Cubic Inch Rev MUNSTER!!
Transmission: Turbo 350
Axle/Gears: GM10 bolt w/4.56 posi
Mine has the same screeching whine to it at idle. It sounds link a horribly bad power steering pump or maybe somewhat like dragging a peice of porcelin across bare steel. I thought the same thing that you did. What model do you have?
Joe
Old Aug 15, 2005 | 07:41 PM
Treys_IROC's Avatar
Car: '89 Camaro
P1SC
Old Aug 16, 2005 | 07:10 AM
rcwest32's Avatar
Just like a Vortech, it's gear to gear. There is no way around the noise. If you want quiet, get a Powerdyne! They make the engine sound stock.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
-=Z28=-
Sep 24, 2015 10:21 AM
Randomtask2
Sep 7, 2015 05:06 PM
