Possible turbo probject add on
Old Sep 10, 2005 | 06:46 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
I currently have a brand new, not even run, 383 with a 510 int/exh lift cam, holley 750, weiand team g, 1.94 1.60 cast heads, Pro Mag rocker arms, and all with a stock crank and hyper pistons. I was tossing around the idea of putting a turbo or even 2 on it. I have been reading alot about the junkyard turbo setups, etc. and was starting to think if my hypers would be able to handle a twin turbo setup. Most of the stuff sounds like jibberish to me as I do not know much about power adders. Any insight would be great.
Could I do a tt setup?
Will the hypers handle it?
Types of turbos to look at?
Other options?
Old Sep 10, 2005 | 07:22 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Hyper pistions can be made to hold up if you eliminate detonation (good tune). What is your static C/R?
Old Sep 11, 2005 | 09:40 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Well, I don't know exactly but it is somewhere around 9:1
Old Sep 11, 2005 | 10:10 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Your not going to be able to run much boost with that high of a comp ratio unless your going to use a couple intercoolers and water/meth injection.
Old Sep 11, 2005 | 07:36 PM
89JYturbo's Avatar
That kind leaves a lot of room for guessing. But, at least it ain't crazy high. With the efficiency of todays turbos and related components, 9:1 wouldn't scare me. I run 10psi through my Z24 witha stock Venture Minivan engine in it (stock cast pistons), which has a 9.5:1 SCR. It is not intercooled, but I do spray it with water and alcohol.
Old Sep 11, 2005 | 07:56 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Basically I want to do a little something "extra" than just a decent motor. I am planning on around 400hp out of this one but wanted to do something different but not change what I have already put into it. Which would be a better route, nitrous or turbo(s)? I kind of wanted to stay away from nitrous but am open to suggestions. Remember that this is something that I want to add on and not get crazy with like dumping thousands of dollars into. Should I just forget about a turbo setup?
Old Sep 12, 2005 | 01:49 PM
89JYturbo's Avatar
I don't normally try to talk people out of turbo projects, but this may be an exception. I guess it all depends on what you want. I was going to say youy shouldn't build a turbo system if your goal is only 400hp, but then again, I don't think I'm quite there either. However, my goal was not power, but I wanted something unique. I like the sound and feel of a turbocharged engine. FOr me, there was no question, turbo all the way.
And there is easily potential in the system for way more than 400hp. I think my current turbo system could support ~600+hp at 15-20psi of boost or so if it were pumping into the right engine combo (a stock 90k L98 won't get e to that goal). Thats my long term goal.
Old Sep 12, 2005 | 02:04 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
hey there 89JYturbo what should i do if i just wanted to run a single turbo set up what turbo should i use for about 6-8lbs of boost?
Old Sep 12, 2005 | 02:24 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Sorry for the misunderstanding but I am planning on around 400hp without a turbo. Again, sorry for the confusion. I am trying to be a "little different." At the same time if it is a waste I am not going to do it. If my engine, as is, cannot handle the project then I won't even bother. That is why I am asking. I have no clue as I am new to the power adder scene.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mrbird
Oct 20, 2015 03:43 AM
skinny z
Oct 5, 2015 06:23 PM
