Question about turbo turbine housings
Subscribe
Oct 17, 2005 | 05:34 PM
Seems like this has never been convered here before. But when I look at options for turbochargers, they have several options as to the type of turbine housings available. They include tangential and on-center housings. Now I know what the differences are that these options mean physically, but besides space considerations, why would a turbo buyer choose one over the other? Is one type of housing more efficient or produce more power than the other?
Reply 0
Oct 17, 2005 | 07:47 PM
Tangential are generally more efficient, the only reason to use an on center housing is to fix packaging issues. As a matter of fact I don’t think that anyone is making new tangential housings.
Reply 0
Oct 17, 2005 | 09:47 PM
Thanks. That was exactly the answer I was looking for.
Reply 0
Oct 18, 2005 | 08:52 PM
Quote:
No more tangential housings? Thats stupid. Why would they do that. Almost every turbo setup I've seen uses tangential housings. That makes no sense.
Reply 0
Oct 19, 2005 | 03:03 AM
woops, that second sentance should read that no one is making on-center housings anymore... at least that I know of...
Reply 0
Oct 19, 2005 | 06:27 AM
Hey TurboedTPI, those are some sick numbers! 570 rwhp @ 13lbs of boost? VERY nice. Is that through a stock TPI system? What RPM do you make that HP at? Thanks.
Reply 0
Oct 19, 2005 | 02:48 PM
Quote:
I wanna know too I think I have the same kit he has sitting in the box still ( T-62 from BBS ) and willbe runnnig the same motor
Reply 0
Oct 19, 2005 | 09:52 PM
Turbonetics still offers on center housings.
Reply 0
Oct 20, 2005 | 06:35 PM
Thanks alot guys. I have TPIS large tube runners, an extensivly ported stock base plate and plenum with a 58mm throttle body. It made that power at about 5450 rpm. I like the lower RPM powerband, because its alot easier on engine parts. If it revved higher, i bet the engine would have grenaded by now.
Reply 0
Oct 20, 2005 | 07:38 PM
Yup, that's a lot of power to be making with a stock block and crank.
Sometimes I almost wish I had went single turbo. It might have been installed by now.
Reply 0
Oct 20, 2005 | 11:14 PM
Quote:
When you say extensively ported stock base, do you mean it's siamesed?
Reply 0
Oct 22, 2005 | 12:00 PM
Nope, its not siamesed, its just ported and smoothed very nicely. I compared it to a TPIS big mouth base and the ported stock one just looked like it would flow more. But who knows. I just wanted to make a sleeper.
Reply 0
Subscribe
