getting a NOS kit... now i ...............
Old Nov 1, 2005 | 08:15 PM
ibwsjerry's Avatar
Car: '89 iroc
Transmission: th-350
so i get a NOS 5151 kit comming. It has a 150 jet in it. Anything i should do before i spray the hell out of it? The car runs ***** to the wall now. I just want to be 110% sure and to make sure i dont miss or over look anything. its got a newer stock fuel pump, accel super coil, new cap and rotor, new wires, new plugs... so the ing. should be ok? Its on a WOT switch also. any words of wisdom?
Old Nov 1, 2005 | 08:28 PM
3rd gen V8's Avatar
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
just make sure that u get the tune up just right and dont abuse your engine with a heavy foot on the WOT nitrous switch lol.
Old Nov 1, 2005 | 10:36 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Start spraying small at 1st, then go bigger
Use the search button for starting to use the n2o,
You need a bigger fuel pump if you are going bigger than 50hp shot.
Old Nov 1, 2005 | 11:26 PM
ibwsjerry's Avatar
Car: '89 iroc
i did do a search. Part of the serch was sayin the stock fuel pump was good up to a 150 shot. NOS says it also
Old Nov 2, 2005 | 07:27 AM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
I dunno, over a $100 fuel pump you"ll risk a $1500 motor?
Old Nov 2, 2005 | 09:42 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Re: getting a NOS kit... now i ...............
Ya, take the 150 out and put in the 50 jets. Then 75, then 100. This is why n2o gets a bad name. Nitrous is easy power, too easy.
Old Nov 2, 2005 | 03:24 PM
83 Crossfire TA's Avatar
5 gallon bucket in the trunk to carry the engine home in.
AAA Gold memebership paid up.
Naw, have fun, just like anything else, only do it if you can afford the possible consequences, and money/time spent ahead of time testing and for a safer setup tends to postpone the accedent that causes the consequences...
Old Nov 2, 2005 | 05:01 PM
ibwsjerry's Avatar
Car: '89 iroc
the book says for both a 100 and a 150 shot = stock plugs and stock timing... i think that wrong, since now i got ngk 8 plugs and 12* timing? what u guy doin for plugs and timing?
Old Nov 2, 2005 | 05:02 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Start off with a 75 shot; it'll only make you want more, I don't see a 50 shot doing anything but wasting a little bit of your gas. Get some colder plugs, pull a little bit of timing out, run some octane booster and put it on a WOT switch. Start off more safe than sorry and slowly work towards getting nuts. Scanning software to monitor knock counts and a WBO2 are worth their weight in gold both N/A and on the bottle.
Old Nov 2, 2005 | 11:11 PM
1meanGTA's Avatar
Car: 1987 GTA/1998 Explorer
Engine: 355, trick flow heads, zz409 cam, 3
Transmission: 700r4, shift kit, valve body
Axle/Gears: precision 3.73's, auburn diff
whats the best way to use a throttle activated nitrous system? i've always been afraid of pushing it, and have only used it a few times. i would always slowly get the rpms up over 3000 in 3rd gear, with the throttle at about 2/3, then floor it once i passed 3k. i always let off it, and did the same thing for overdrive. can i leave it floored through the shift, or can i spray it before 3000 rpm? use it in 2nd gear maybe even? i have 3.73 gears, mod list in sig.
Old Nov 3, 2005 | 12:36 AM
one step colder and stock timing up to about 225hp.
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZ1989
Sep 4, 2015 11:54 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
