will 76cc heads drop me low enough to run boost?
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
the only two reason im not boosting this new motor is because i would need to purchase a forged crank and my CR is too high.
right now im running stock trickflow 23 degree heads with 64cc chambers, eagle hbeams, weisco 10.5-10.6:1 slugs and a scat cast crank. would 76cc heads drop me low enough to run approx 8lbs???
im going to get my block splayed and a forged crank to handle the power but i dont know if it would be best to get new pistons to drop the CR or if i should get another set of heads (if that would drop me low enough).
any suggestions?
any suggestions?
Is this on a 305 or a 350? Is your true current compression at 10.5 now? Reason I ask is that 64cc heads on a 305 you are probably less than 10.5 now (since 305 pistons assume a 58cc head). Just trying to nail down exactly where we're starting from.
Car: 1991 Z28
Engine: 383
no i forgot to say in my first post this is a 383 im building so i dont know the exact compression but it will be around 10.5:1, the 305 is actually coming out this weekend
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
Give a list of parts that you want to use. Amount of boost, intercooled? Alky-inj.? We're shooting in the dark w/ nothing go on but 383 and 76cc heads.
Car: 1991 Z28
Engine: 383
well in the first post i listed the approx compression, what heads im using, the amount of boost i would like to run and yes it will be intercooled (TT setup single intercooler). alky injection is a possiblilty but wasnt leaning towards it
Engine: 355
Axle/Gears: 4.11
It's looking like 10:1 static compression w/ the numbers that I was using. Assuming that there has been no machine work done to the block on a .03 overbore.
You can get away w/ it, but it'll require a good tune.
Car: 92 Z28
Engine: Boosted LSX
Do you already have some of the parts? You say you havent built it yet. So if you dont have parts yet why not just get some low comp. pistons for the get go.?
Car: 1991 Z28
Engine: 383
cam is 230/236 .510/.520
the reason i ask is because the 383 im building now has good weisco slugs in it and i basically wanted to turn this motor into a turbo motor in a year or so. it was either get new pistons or heads and swwapping heads for one is much easier when the motor is in and two, i wanted to get a better flowing set of heads than the trickflows anyway
If you have flattop pistons in a 383 with a set of 76cc heads you could have compression as low as 9.1:1 and as high as 9.7:1, depending on piston deck height, gasket thickness and how many cc's worth of "dish" there is in the piston valve reliefs.
.025" deck height + 9cc Fel Pro .039" head gasket + 7cc of piston valve reliefs = 9.1 compression
.000" deck height + 9cc Fel Pro .039" head gasket + 5cc of piston valve reliefs = 9.7 compression
