Ring gap difference NOS vs psi
Old Nov 4, 2005 | 02:55 PM
Twelvz's Avatar
Car: 89IROC
Engine: Forged 355 AFR195
Transmission: 700R4 Vigilante Converter
Axle/Gears: Strange 12 bolt 3.73
When building a motor if you want to add a power adder...Whats the difference between boost and nos when considering ring gaps?
If you ring gap for boost will that necessarily be bad or same difference if you spray ?
Old Nov 4, 2005 | 03:30 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I would assume that a blower motor would need slightly more considering n2o is a much cooler charge than what any intercooler could produce.
Old Nov 4, 2005 | 04:27 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If either power adder adds essentually the same amount of extra power then the extra ring gap needed would be equal.
The extra ring gap is needed becuase of the extra heat created in the combustion chamber by burning extra fuel.
The temp of the inlet ( NOS) has nothing to do with it.
Extra power = extra combustion heat... requireing larger ring gaps. Most piston manufacturers supply ping gap recomendations for N/A and supercharged/ NOS applictions.
100hp is 100hp of heat acting on the piston top and rings.
Old Nov 6, 2005 | 04:20 PM
REALPOWER's Avatar
Car: 1984 Camaro on steroids/ 1987 iroc-z28 5 speed.
Engine: 383 nitrous motor / poindexter 305
Transmission: Th350
Look it up in a vizard book. I'm sure he says something about it, although I cant remember. I do remember him building a 900 hp nitrous motor for about 3500 dollars, though.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
fasteddi
Sep 2, 2015 10:29 AM
JHX
Aug 29, 2015 02:30 PM
Dialed_In
Aug 20, 2015 01:45 PM
TreDeClaw
Aug 14, 2015 06:58 PM
