HELP 92 firebird w/vortech v-2 sc
we have a 92 firebird with a vortech supercharger v-2 after 4000rpms the car loses pull and starts to break down. We belive its a fuel realated problem has anyone seen this befor or even close.... help need som guidence ITS A 5.7 TPI
just put on
the sc was just put on about 6months ago but has gave us problems from the begining we think the fuel injectors are shuting off due to to much presser they're stock the plugs are gaped.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Just something I experienced on a ford. We had to put a one way valve between the map sensor and the vacuum line. Cause every time he hit boost it would fall on its face. Also if you have 22 lbs injectors you need like 80 to 100 psi fuel pressure. Gap plugs at .35 or less.
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
