general turbo question
Old Nov 19, 2005 | 10:36 AM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
Ok, me and my dad got into a discussion I said using a muffler with a turbo helps because if it's a properly designed muffler it'll help scavenge exhaust more and help the turbo draw more air. He said that not having a muffler after a turbo helps reduce back pressure.
Old Nov 19, 2005 | 10:51 AM
Scheister's Avatar
Car: 85 IROC
id agree with your dad
Old Nov 19, 2005 | 11:15 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
You want the least restriction possible after the turbo, hell turbos work great as mufflers if you're worried about noise
Old Nov 19, 2005 | 11:25 AM
Scheister's Avatar
Car: 85 IROC
the only current production car in the US not to come with a muffler is turbo
Old Nov 19, 2005 | 11:29 AM
cool guess I was wrong. thanks, glad I didn't have a bet on it or anything
Old Nov 21, 2005 | 10:54 PM
83 Crossfire TA's Avatar
you've read too much muffler advertizing BS.
Old Nov 22, 2005 | 03:46 AM
I believe I read about a muffler scavenging helping a turbo on this board or at least a board. I don't pay much attention to any advertising for anything.
Old Nov 22, 2005 | 12:07 PM
Heh, and you believe everything everyone says?
Even assuming that you design something that does do scavenging, that implies that you have some sort of pulses to work off of, which you don’t have at all after a turbo. Since what you basically have is smooth flow after the turbo anything added into that path basically becomes a restriction.
in other words, turbos change the rules you play by there anyway
Old Nov 22, 2005 | 09:47 PM
PhLaXuS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: 2.73 Posi w/Disc
I believe the general consensus is to run a straight pipe from the turbo out to the rear of the car and only muffle it as little as required to quiet the exhaust to "reasonable" levels for the environment.
Old Nov 23, 2005 | 03:33 AM
thanks. good thing I didn't make a bet
fasteddi
Sep 2, 2015 10:29 AM
lt1z350
Aug 28, 2015 05:57 AM
PestilenceIV
Aug 20, 2015 03:32 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
