Are super chargers alway under boost?
Car: 88IROC vert and a 83 w/evo body
Engine: 400 and 350
Transmission: T56 and 700R4
Axle/Gears: 323 and 373
I was wondering if the Vortech superchargers always carry boost even at idel? I have mine on the way and just thought about this.
All the Vortech Superchargers I know of are centrifugal like my S-Trim in my 91Z. They do not build boost at idle even though the belt is spinning. And watching my boost guage I can still see it in the vacuum portion of the guage at idle (measured in Hg), even slight/moderate throttle. When you go WOT then it will build boost past a certain RPM, dont remember exactly what it is on my car (its been down for months w/ blown tranny).
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Boost? Your supercharger is moving air at idle. As long as its spinning its moving air. But its not spinning fast enough to build excess pressure ie boost.
No.
Just becuase the impeller is spinning doesn't mean it's moving any air. Centrifugal compressors "stall" at low RPMs and/or low airflows. Yes, if you slam the throttle shut at high RPMs you'll get a pressure spike in the piping between the blower and the throttle. And at modest RPM you won't have any meaningful pressure even between the blower and the throttle.
YES. Of course they are always producing pressure, just not enough to offset/change things at low throttle/vacuum..
They provide positive boost once they overcome the vacuum and thats when they pressurize your intake=boost PSI you feel under your butt.. lol
Whoever says they don't, needs to go and look at a real supercharger and actually start the engine..
STALL at low RPMS.. BAHAHAHAH....That's a funny one..
Engine: 400 and 350
If they do have boost at idle? then does the runner length matter? I was told once that a forced induction doesn't care abour runner length so I was thinking if this is true then I could make a custom intake and not worry about the design. Thought?
Car: 1991 Pontiac T/A Vert
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Originally posted by Damon
No.
No.
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
Originally posted by grover85
Ok you pull the pipe going to the tb while the car is idleing and see if air is being pushed. On my buddies stock mustang with a ati kit we found air leaks at idle.
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
No.
No.
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
