Procharger d1sc on 305
Old Dec 13, 2005 | 07:29 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
ok i've done some research and i want a procharger!!!!
question is this P1SC or D1SC ?
i have a 305 TPI 5 speed now
Accel tpi base and large runners
Crane 2032 Roller cam with comp cams 1.6 roller tip rockers
19lb hr injectors flow matched and clean
walbro 255 fuel pump
headers, 3" catback
i have the capability of burning my own proms and will eventually switch to a 7749 ecm
i will be building a 350 L98 block in the future most likely for boost
so will my current 305 be okay with the D1SC, do i need modifications or different fuel injectors?
also the polished intake tract option i assume is for the ducting from the procharger to the throttle body
willie..... your my idle
Old Dec 14, 2005 | 11:10 AM
5.7iroc-02ws6's Avatar
Car: 1988 IROC/02 WS6
Engine: zz3 crate w/12 psi ATI and stock ls1
Transmission: 700r4 w/2800 stall and m6
Axle/Gears: 3:42 10 bolt-both cars
Depends on boost #'s... I am sure the P1sc would be plenty for the 305 and the 350 but the d1sc would be nice to have in the future.. My thoughts, buy the d1sc (if you don't want to buy bigger injectors) put a larger pulley (less boost) run it on your 305 and when you do the 350, bump your injector size and the boost....
Just my .02...
Old Dec 14, 2005 | 08:20 PM
KS91Z28's Avatar
I agree with 5.7 iroc-02ws6, and as far as getting polished tubes, the only tubes that will get polished would be the ones you can see from the top like in 5.7 iroc-02ws6's sig.
Old Dec 15, 2005 | 03:57 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
cool! sounds good guys
Old Dec 16, 2005 | 05:16 PM
leeperryracing's Avatar
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
go with the D1-SC if you can afford the few hundred more over the P1-SC...that way if you happen to grow into a 350 or 383, you'll have more than enough blower for the added displacement. Think ahead buddy and you'll save yourself some money in the long run.
Old Dec 19, 2005 | 11:57 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
ok one more question, every where i look the d1sc's lowest boost option is 15lbs
how do you guys get 10lbs? i keep hearing about a 4.25" pulley, is this a pulley you have to buy elsewhere?
Old Dec 20, 2005 | 07:44 AM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Check out this post, Willie covered pulley sizes and ATI's "produced" boost ratings
Old Dec 20, 2005 | 04:01 PM
KS91Z28's Avatar
When you order the system, the engineers at ProCharger will take the information you give them about your application and spec out the correct pulley. They also have 4.50", 4.75", and 5.00"
Old Dec 20, 2005 | 06:23 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
great, i think i'll run 10#'s for now using the fmu, then later upgrade the injectors and 7749 ecm, 10#'s should be okay on my 305 with 19lb injectors correct? it says 12lbs requires 24lb injectors, i cant wait till i get the procharger!
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
