N2O on stock L98
Old Dec 21, 2005 | 01:20 PM
3rdgen92maro's Avatar
Car: 1995 Firebird Formula
Transmission: Th350/4k stall
Axle/Gears: 10 bolt with 3.42s
N2O on stock L98
i currently have a stock l98 with 80,000 miles. i want to spray it but dont know how big i should go with the stock internals. any advice will be great.
Old Dec 21, 2005 | 01:31 PM
Scheister's Avatar
Car: 85 IROC
kit i have is a discontinued NOS kit and it was made for a stock 305 or 350. it was 110 for 305 and 150 for 350.
Old Dec 21, 2005 | 01:37 PM
i was thinking 100-150. will i have to upgrade my fuel pump. i know i have to retard the timing but is there anything else i need to do.
Old Dec 21, 2005 | 01:42 PM
Scheister's Avatar
Car: 85 IROC
i havent on my 305 with a 110 shot, the directions dont even say to retard the timing. the instructions for it say with different jets its a 150 shot for a bone stock 350 with stock timing and plugs.
ive been running the 110 shot on mine for quite a while with no retarding and stock plugs and its been fine. the motor looked great when i pulled the heads to have them ported, polished and rebuilt.
Old Jan 9, 2006 | 06:21 PM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Scheister any chance I can get you to post the jet chart for that kit? I've got the same kit minus the bottle on my car.
Old Jan 9, 2006 | 10:42 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I just sent you an email with the old 5151 instructions attached.
Cheers!
-Schultzy
Old Jan 10, 2006 | 01:22 PM
Email recieved, much appreciated. This isn't the kit I have but it gives me a general idea of where I'm at. One question, is the jet rating for a pair of jets firing into twin nozzles? Mine's a single jetted spray bar in a sandwich style plate (may be an LT1 setup but it came off of an L98 Camaro). I'll have to check but I believe I had a 57 and a 36 jet in there and that combo works unreal.
Old Jan 10, 2006 | 07:52 PM
Car: 1989 GTA
Yes, on my setup the jet sizes are for a pair of jets firing into twin nozzles (two N2O pills, two fuel pills).
Is this your setup?
http://www.holley.com/data/Products/...A5060-SNOS.pdf
-Schultzy
Old Jan 11, 2006 | 10:37 AM
71 41 jets are going in tommorow!!! Thanks alot guys that answered my questions.
lt500r55
Sep 1, 2021 01:30 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
TheExaminer
Aug 19, 2015 10:07 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
