possibly a stupid question
Old Dec 27, 2005 | 05:00 PM
j0n's Avatar
j0n
Car: 1999 Corvette
Axle/Gears: stock dif/3.42s
if you were to install a single turbocharger on a v8, or any engine in a "v" formation, should you route both banks of the exhaust to the turbo, or can you get away with one bank going to the turbo and the other bank flowing out the tailpipe?
Old Dec 27, 2005 | 06:28 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
A single turbo needs both banks feeding it.
Don't ask.....Can I get away with using one bank?
You can use one bank....it just won't work right.
Old Dec 27, 2005 | 06:43 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Saab used one bank of a V6 to drive a turbo. According to them, it was 'inovative'. IIRC, they called it 'asymetrical turbocharging'. Of course it was inovative, nobody else did it because everyone else knew the turbo would work better with all of the engines exhaust used to power it.
I'll see if I can find the link...
Old Dec 27, 2005 | 11:35 PM
j0n's Avatar
j0n
Car: 1999 Corvette
ok thanks for the info...how do most single-turbo motors route the plumbing?
Old Dec 28, 2005 | 10:21 AM
fbodman's Avatar
Car: 1984 Z-28
Engine: L69
If both banks feed the turbo what do you do about your exhaust system? Is there still a need for a muffler and tailpipes on a turbo car?
Old Dec 31, 2005 | 08:01 PM
Grim'91Z's Avatar
Car: 1991 Camaro Z28
Engine: L98 5.7L V8
Transmission: 700R4 Auto
I'm pretty sure you do.
Old Jan 1, 2006 | 02:16 AM
83 Crossfire TA's Avatar
not really, the turbocharged neon comes without a muffler...
Old Jan 1, 2006 | 09:12 AM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
Yeah, and then some of these idiots by fart pipes for them... DUUUUUUUUUUH!
Old Jan 1, 2006 | 11:25 AM
Grim'91Z's Avatar
Engine: L98 5.7L V8
But you still need plumbing.
Frozer!!!
Jan 19, 2024 04:55 PM
Cleotiz
Jan 6, 2018 08:56 PM
87iroctheo
Dec 4, 2016 11:47 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
