B&G twin turbo installation progress
Old Jan 25, 2006 | 10:08 PM
87IROC350's Avatar
Engine: 5.7
I got the passenger header and turbo in place this evening.
Click here to see the installation pics
I'll keep updating as I progress. I'm going to hit it hard this weekend.
Old Jan 28, 2006 | 10:15 AM
Slick Shoes's Avatar
Car: 83 T/A
Engine: Carbed 350
That looks to be a great kit... You got me all interested!
Old Feb 8, 2006 | 08:12 AM
drex's Avatar
Car: 87 formula and 85 olds delta 88 2 d
Engine: 60's 350 holley carb and intake
Transmission: muncie 4 speed with centerforce
Axle/Gears: 3.42 99 camaro rear w/ discs
what kind of headers are those? does the other turbo sit in the battery tray as well? i looked on b&g wesite and no f body's?
Old Feb 8, 2006 | 09:27 AM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Good looking kit. What turbo did you go with? Is that a Master Power T70 or Master Power GT45?
EDIT: Where does the turbo oil return line go to the oil pan. It looks like it will be almost flat for a ways before it makes it past the fender well, true?
It looks like the comp. housing is clocked for an intercooler. What size IC?
Old Feb 8, 2006 | 07:25 PM
87IROC350's Avatar
Engine: 5.7
If I recall correctly they are two 6031 ball bearing turbos and yes the turbo fits in the other battery tray. B&G fabbed the entire kit including the headers. The oil return will run to the oil pan but I haven't decided how I am going to run it yet. I am thinking of running it down through the battery tray and through a hole in the frame (already there from factory). I'm going to use 10 AN hosing on a steady decline so it should be fine.
I think the intercooler is sized and a little over 4" thick. The kit has potential to push about 1000hp with the right engine setup. My plan is to run it with around 8lb on my current engine and end of year build a bullet proof low compression engine to crank up the boost.
I have the other header ready to go on I just need to weld the O2 bung in the downpipe before I put it on.
When you go to my site there should be a link to return to the main page and there should be pics of the complete setup there.
Old Feb 8, 2006 | 07:37 PM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i know this is kind of a silly question, but where is your battery going to go? and i assume you have deleted your vapor can a while ago.
nice looking setup so far.
Old Feb 8, 2006 | 07:45 PM
87IROC350's Avatar
Engine: 5.7
I'm mounting the battery in the trunk. I have box so it will pass at the track along with a kill switch but if I wasn't worried about it passing at the track I would mount it where the spare tire goes. I saw somewhere they make a bracket that bolts in to allow the battery to be easily secured in there.
fasteddi
Sep 2, 2015 10:29 AM
sailtexas186548
Aug 26, 2015 03:32 PM
1985chevydude
Aug 22, 2015 05:36 AM
crazynights
Aug 21, 2015 06:53 AM
rsrmoore
Aug 7, 2015 08:44 PM
