nitrous question
Old Jan 25, 2006 | 11:34 PM
muteboy49's Avatar
Car: 84 Camaro
Transmission: dont have one yet
Axle/Gears: 3.42 spool on the way
nitrous question
ok guy my 350 is going to have at least a 10:1 CR and its going to be a mainly n/a motor but i definitely want to spray while im at the track. would it be safe to run say a 50 shot? these are cast pistons too
Old Jan 26, 2006 | 12:18 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
yes, with proper safety stuff(low fuel press cut-off, window switch etc.)
Old Jan 26, 2006 | 02:26 PM
muteboy49's Avatar
Car: 84 Camaro
thanks man
Old Jan 27, 2006 | 01:07 AM
NOSFEDGTA's Avatar
get you a wideopen throttle switch and wire everyting correct and you can spray 100 all day and 150 occasionaly...
Old Jan 27, 2006 | 08:15 AM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I agree, 50hp you can barely feel in a decent v8.
Old Jan 28, 2006 | 11:12 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
you'll get bored of 50HP really quick. There is no set point as to where a motor will blow up... Nitrous won't kill your motor detonation or too much power for the parts will. So long as your tune is good your motor will easily survive a 150 shot ...unless you're already making a ton of HP on those cast parts...
Old Jan 31, 2006 | 02:21 PM
92camaro's Avatar
Make sure you have a good tune on the car and 150 won't be a problem. Pull timing, run 2 step colder plugs, good gas, and read the plug after a run.
Old Feb 5, 2006 | 02:01 PM
firebirdowner89's Avatar
Car: 89firebird
Engine: 355 TPI
Transmission: world class T-5
Axle/Gears: 3.73 posi
hey man i have a question, im going to probably put a 100shot on my 305 TPI but i just need to know that it will be safe so i dont blow my motor..can u give me some tips on doin this...THANKS...
Nick
Old Feb 5, 2006 | 05:08 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Search my name,
so far, so good with me.
MustangBeater20
Oct 29, 2022 09:20 PM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
