Turbo ?'s
Old Jan 31, 2006 | 04:07 PM
black86iroc4tim's Avatar
Car: 1986 IrocZ, Ford Escort(winter beater)
Engine: freshened 305, Turbo Plans in the future.
Transmission: 5-speed manual
Turbo ?'s
I wanted to know, what is the ideal compression for a v-8 turboed to about 6-7psi?
Old Jan 31, 2006 | 05:46 PM
Angelis83LT's Avatar
Car: '83 Berli, '84 Berli, '84 Z28 HO
Engine: L69, LG4, L69
Transmission: TH700-R4, TH700-R4, T-5
Axle/Gears: 3.08, 3.08, 3.73 Posi
not positive. but 8.5 to 9 is good.. which is stock compression on most of the camaros.. the HO's hda like 9.5 i think.. of course.. depending on what you are going to run along with then it is anyones guesstimate.. but everyone i talk to says 8.5 to 9 is a good range...
Old Jan 31, 2006 | 10:00 PM
Thanks, I was also wondering if putting 350 heads with 64cc chambers on a stock 305 would lower the compression from 9.5:1 to around 8.5:1 because i have a set of mildly ported heads with good vavles and seals.
Tim
Old Jan 31, 2006 | 11:00 PM
79vette's Avatar
Car: 1979 Corvette
Engine: 355, TFS heads, comp 270H cam, 10.5 comp.
Transmission: 700r4/ 3:55 posi/ 2500 stall
With 8.5 compression you can run higher boost than 7 psi in fact you could probably do 10 psi with out much worry. assuming your timing is good and your running 91 or better octane and your quench is not bad.
Old Feb 1, 2006 | 04:43 PM
SleeperFromHell's Avatar
Car: 92 RS Vert, 86 Iroc
Engine: Blown 350
Transmission: Slushbox
8 Psi? 9:1 should be used to be safe.
I ordered my 383 with 8:1 but i plan on running 15 psi on 93 octane pump gas.
Old Feb 2, 2006 | 04:13 AM
83 Crossfire TA's Avatar
that's like asking what is the ideal compression for any engine… a downright stupid question without any details.
I could build an 11:1 engine that would be fine with that boost and I could build an 8.5:1 engine that wouldn’t tolerate it, and even then it would depend on what that boost is coming from, what the boost curve looks like and where exactly you see that boost relative to the torque peak.
On the other hand, with the safety leaway built into most cars, you can run that on most stock engines…
Old Feb 2, 2006 | 03:54 PM
Thank you all for answering my stupid ?'s. I am new to this whole turbo thing and just need to do alot of reasearch.
Tim
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
