Super Charger
Old Feb 8, 2006 | 02:33 PM
91Z28CAMARO32's Avatar
Car: 91 Z28 CAMARO
Engine: 383 STROKER TPI
Transmission: TH-700-R4
Super Charger
CAN U PUT A SUPER CHARGER ON AN ENGINE THAT HAS 9.25 OR 9.50 COMPPRESION
Old Feb 8, 2006 | 03:10 PM
SleeperFromHell's Avatar
Car: 92 RS Vert, 86 Iroc
Engine: Blown 350
Transmission: Slushbox
Re: Super Charger
Yes
Old Feb 8, 2006 | 04:11 PM
Shagwell's Avatar
Car: projects.......
yes, but the type of pistons will have a key roll in the amount of boost you'll be able to run, which will already be lesser due to the compression...
- reminds me why we run blown methanol, 30% over-drive on an 871 w/ 12.5:1 compression, motor turns 10k, so the blower is zingin'
Old Feb 8, 2006 | 04:36 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
To give you a more detailed answer to that question......what type of supercharger,heads and pistons
Old Feb 9, 2006 | 12:58 PM
Car: 91 Z28 CAMARO
vortec supercharger i have stock heads but they are all been redone for a 383 and im running keith black pistons
Old Feb 9, 2006 | 04:03 PM
Shagwell's Avatar
What series Vortec? Y, S, T ...etc? hyper or forged KB's? - sounds like you'd be in good shape, biggest thing is you need to know is your top ring gap. KB's have specail ring-gap requirements due to the higher mounted top-ring. Make sure it's set loose enough to allow for a boost application. - check KB's web-site for their specs.
Old Feb 9, 2006 | 06:37 PM
Car: 91 Z28 CAMARO
Hypereutectic aluminum
Pistons, Hypereutectic, Flat Top, 4.030 in. Bore, 1/16 in., 1/16 in., 3/16 in. Ring Grooves, Chevy, Set of 8
is this a good piston for a 383
Old Feb 10, 2006 | 04:54 PM
Shagwell's Avatar
yeah, KB makes good pistons. - not ring sizes, ring gap . As in the space between the ends of the top ring, when in the block.(check KB web-site on how this is measured) KB's are very particular about this.
Old Feb 10, 2006 | 05:19 PM
flrtin1's Avatar
Engine: S/B
With the higher compression and hyper pistons you will have to be very very very carefull about detination.......lower boost.....lower timing.......run on the rich side and keep your octane level higher
no green
Jan 9, 2016 09:22 PM
Zell1luk
Sep 29, 2015 10:36 AM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
Formula_88AE
Sep 3, 2015 01:47 PM
