compression + NOS
Old Feb 26, 2006 | 06:31 PM
pimpflea's Avatar
Car: 1990 IROC-Z Coupe
Engine: 383
compression + NOS
I want to run a 150 shot of NOS, my engine is a 383 with 10.5:1 comp and fairly big cam. Do you guys think 150hp is too much to push through this setup? It would just be the occasional once every couple weeks at the strip usage.
Old Feb 26, 2006 | 08:00 PM
luke84's Avatar
Car: 1984 z28
Engine: 355
sounds good to me. I run 10.3:1 compression and 125 shot and have no problems. I had to put spark plugs in that were a couple numbers down colder. I also use 112 octane when I plan on using the nos, just to make sure there is no pinging. and step the timing back 2 degrees.
Old Feb 26, 2006 | 08:56 PM
pimpflea's Avatar
Engine: 383
ok cool, thanks for the tips mate.
Old Feb 26, 2006 | 10:38 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
no worries.
-Schultzy
Old Feb 28, 2006 | 05:38 PM
83 Crossfire TA's Avatar
you're worried about 150hp through an aftermarket short block? Unless the parts used were complete junk you should be able to throw a lot more then that at it.
Old Feb 28, 2006 | 05:44 PM
pimpflea's Avatar
Engine: 383
great, you guys have put my mind at ease, I have had a bloke tell me my engine will crack if I put any forced induction through it. Good to know the consensus around here is the opposite.
btw, the engine is completely new SCAT crank, 4 bolt main, edelbrock E-TEC heads and vortec HSR.
Old Feb 28, 2006 | 06:05 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
What about 12:1? I don't really want to do it but I think it would be fun to run nitrous. I'm under the impression that my compression is too high to do it safely without lots of extra work. I.E. Fuel system specifically for the nirtous.
All you nitrous gurus let me know.
Old Feb 28, 2006 | 07:38 PM
luke84's Avatar
Car: 1984 z28
Engine: 355
You defenatly need to make sure that you have plenty of fuel flow! Fuel starvation will kill anything when nos is involved. make sure you have a good pump. aftermarket electric pump on FI or carb. with 12:1 compression 110 or 112 octane wouldn't hurt!
Old Feb 28, 2006 | 09:45 PM
The problem isn’t compression, it’s detonation. Modest shots of N2O will not make the engine significantly more likely to detonate, BUT if it does you have that much more behind that detonation to break parts making carrying it home in a bucket more likely.
junior419
Apr 7, 2025 11:35 AM
FormulasOnly
Jul 23, 2018 08:47 AM
WhteRbt
Sep 21, 2015 09:48 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
IROCZ1989
Sep 4, 2015 11:54 AM
