Engine timing and Nitrous
Old Sep 11, 2000 | 12:05 AM
89ROC's Avatar
What's the highest timing you have gotten away with without detonation? I have the NOS 150HP kit and I sprayed with timing @ 5* BTDC and suprisingly there was NO detonation.
I had 93-octane fuel and 48PSI.
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
A4, bone stock except for the Flowmaster.
The crazy fool racer of the UNfamous SW crew.
Old Sep 11, 2000 | 04:23 PM
Formula-91's Avatar
I normally run at 16 degrees initial. If I'm going to spray, I back it down to 12. I'm running the 150 shot cheater kit, and usually use 93 or 94 octane. I've never run into a detonation problem.
91 Firebird Formula. Converted to carb. Holley 750. Forged Flat top pistons. 10.5 to 1 compression. ZZ-9 Cam. Ported L98 Heads.
150 shot NOS, 700r4 w/ 3000 rpm converter and 3.73s in the back. Headers w/ full dual exhaust. 27.5 inch McCrearys. (free slicks)
12.98 @ 106 Natural,
11.83 @ 113 NOS.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
