LS-1 twin turbo goes 350 mph!!
Old Dec 16, 2000 | 06:45 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
This is a misleading subject but you'll like it anyway.. these guys are building a (soon to be in) production autogyro that will cruise at 350 mph... powered by none other than our favorite brand - Chevrolet! A twin turbo LS-1 to be specific! Too cool...
http://www.cartercopters.com/prototype_spec.html
Steve
Old Dec 16, 2000 | 07:42 PM
84TransAm's Avatar
I wonder how long the terrain would allow u to cruise at that speed
--Steve S-- 84 Trans Am 305 HO 5 speed, completely stock will soup up when i get some $$$$$$$$$$
Old Dec 16, 2000 | 07:43 PM
84TransAm's Avatar
DOH!
Old Dec 17, 2000 | 12:45 AM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
It says it uses 2 turbos in series.. would that be where one turbo blows into the intake of another turbo, and then to the intake of the engine?
Wouldn't that be kinda pointless? Just curious..
Old Dec 17, 2000 | 04:39 AM
Novaguy76's Avatar
yes it is... and beleive it or not it is a pretty good set up. This is how the last RX7 turbo motors were (if I remember correctly). Sence a turbo works off of the speed of the air feeding it the first turbo would force the second turbo to spin faster because it was forcing the air into it. Then because the second turbo is spinning fster you can get more boost at a lower RPM then before. Also the higher the RPM the more the boost. Nothing but good....lol.
Old Dec 17, 2000 | 09:36 AM
ZZ3Astro's Avatar
Car: 87 Iroc
Also, keep in mind that this thing can cruise at 45,000 feet! At the altitude you need both turbos just to produce 300 horsepower!! But at 25,000 feet it can produce 600 so on the ground it must be theoretically capable of much more..
Turbo's rule!
steve
Old Dec 17, 2000 | 04:10 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
FWIW,
In a single stage T/C setup the limit is 60 PSI of boost depending on atmospheric conditions, but in multi staging you can run up much higher, ie 250 PSI of boost.
Also, they can recover all the more energy from the exhuast heat that way
bjpotter
Jan 22, 2019 12:27 PM
Infested
May 22, 2018 11:56 PM
1986Z28OWNER
Dec 13, 2015 10:19 PM
Eric-86sc
Aug 24, 2015 09:01 PM
86White_T/A305
Aug 17, 2015 12:16 AM
