Getting N20:Can i use the carter mechanical pump or should i get a electric pump?
Old Jan 29, 2001 | 08:29 AM
firebird305's Avatar
In about a month,I will be getting a NOS power shot system (125 horse shot)for my firebird. I wanted to upgrade my fuel pump just to be safe,But i'm undecided on what pump to get. The carter mechanical pump i'm looking at flows 120 g.p.h. at 6 p.s.i.,And the tech guy at summit said that this should be more then adequate. Is he right,or should i get and electric pump?
82 firebird with 305H.O.,Block bored .30 over,Keith black hyperutectic flat top pistons for 10 to 1 compression,Turned crank,Magnafluxed connecting rods,Melling H.V. oil pump,and double roller timeing chain,Ported and shaved heads w/3angle valve job,Z-28springs,Summit push rods and comp cams magnum roller rockers,Ported Edelbrock performer r.p.m.intake,Carter 625 afbcarb,Accell spark plugs,wires,and H.E.I.super coil,Heavy duty cap and rotor,Clevite performance cam with 450-460 inches of lift,Comp cams lifters,700r-4 tranny rebuilt with trans-go rebuild kit,corvette servo,New torQue converter,Flowtech headers,Flowmaster muffler,3.73limited slip rear end,Energy suspension bushings from front to rear,Energy suspension tranny mount,New center link,ball joints,trans-am steering box,ASP power pully.
Old Jan 29, 2001 | 09:53 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
A mechanical fuel pump is suffecient up to 150HP shot of spray,after that I would say go with a dedicated electric fuel pump for the NOS only.
Old Jan 30, 2001 | 07:54 AM
Thanks for the help,Superman,I think that's the pump i'll go with.
RazorN8
Jan 7, 2022 11:44 AM
theshackle
Mar 5, 2017 06:37 PM
Glowsock
Jan 9, 2017 04:06 PM
krisner89
Carburetors
Sep 20, 2015 08:56 PM
Dialed_In
Aug 20, 2015 01:45 PM
