Tuning a turbo?
Old Jan 9, 2001 | 11:21 PM
pods8's Avatar
Tuning a turbo?
Well I've looked into turbos before for a project(this a v6) basically I know I can fabriacte the exhaust and intake parts for the system, thats not what has held me back. What my question is what needs to be added to the system to run it up to about 8 or 9psi. A chip could do it I think but that would take alot of burning knowledge, I've heard a rising pressure fuel regulator would supply the fuel needed too. What all is needed in the system to tune it effectivaly?
-pods
88' Sport Coupe W/ T's
2.8->3.4 5-speed, accel coil-8.8 wires w/ bosch platinums
black and silver, grey interior, w/ 95' cloth seats, 3way power driver
Old Jan 10, 2001 | 09:17 AM
scauffiel's Avatar
Get/read Corky Bell's book, "Maximum Boost" - should answer many of your questions.
Steve
Steve's Trans Am Temple
Old Jan 10, 2001 | 11:39 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
The same things that are involved in tuning an NA car, or a supercharged car. You need the right amount of fuel for the air going in. Simple as that. If you've got a MAF system, make sure the MAF doesn't get maxed out and it should take care of it for you. If you have a MAP system, make sure the fuel/timing maps show positive intake pressure (i.e. get a TTA chip in the meantime). Finally, if you can't do that, get a rising rate fuel pressure regulator which will add x psi of fuel for y psi of boost to get the right air/fuel ratio. It's a simple concept, but a PITA to do if you don't have the right equipment (DFI, chip burners, etc...)
A.
Old Jan 21, 2001 | 01:19 AM
Z28Maniac's Avatar
Could you explain what you mean by making sure 'the MAF doesn't get maxed out'?
'68 Camaro - Vortec 350
'85 Camaro Z28 - 305 TPI - FOR SALE
'91 Camaro RS - 305 TBI
Old Jan 21, 2001 | 02:14 AM
GMI FAST's Avatar
The MAF sensor can only support a certain amount of airflow, then it becomes a restriction in your airstream. Just think of the gobs of fast-moving air trying to pass through the screens and get measured at the same time...
Old: 1989 Formula, 383", DFI, built 700R4, TFS heads, Mini-Ram, Vortech S-trim 15 psi, 3.70 gears
Best ET: 10.796 @ 125.8 mph
New: 1989 T/A, 406", Accel Pro-Ram, DFI, AFR heads, HRC Turbosystem, NOS 150-hp dry kit, TH400 w/GV overdrive, 9" w/3.70 gears, 8-pt. S&W rollbar, 18" wheels
Best ET: Spring 2001
Employed at:
Hahn Racecraft
Accel EMIC/DFI Tuning
Turbosystems & Custom EFI
Member of Midwest F-Body Association www.mfba.org
Old Jan 21, 2001 | 10:26 AM
Dan W's Avatar
I think what he meant by MAF maxed out is that there is a maximum ammount of air that that the MAF can measure... not nessicarily flow.
Old Jan 21, 2001 | 09:31 PM
Z28Maniac's Avatar
How can you tell what that amount of air is or how to prevent it?
Old Jan 22, 2001 | 11:30 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
I believe for our MAF unit, it maxes out at 255 grams of air per second.
Andris
Old Jan 22, 2001 | 12:34 PM
Dan W's Avatar
There was a thread on this within the last month... you might want to do a search.
[This message has been edited by Dan W (edited January 22, 2001).]
Old Jan 22, 2001 | 02:13 PM
maniacc's Avatar
z28maniac,
If you are still using the stock ECM too control your engine, you will need a scanner to read the MAF output, you can use something like Auto X-ray, Diacom, or Ease scantool....
Hope this helps ya,
later,
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
and NOW supercharged!!!
http://maniac.megamania.com
Old Feb 6, 2001 | 08:21 PM
Greenshamrock77's Avatar
I second the notion of getting Corky Bell's "Maximum Boost" I have that book, it is excellent. I got it BANRES & NOBLE. They usually have it in stock.
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
Tarizza
Sep 24, 2015 12:57 PM
eustodp
Sep 20, 2015 05:09 PM
R13_Braz
Sep 18, 2015 05:00 PM
