Boost Gauge readings?!?!
Old Mar 12, 2001 | 12:48 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
I hooked my boost gauge up this weekend, and I'm not getting the readings i expect. At idle, the gauge reads 20 on the vacuum side. It doesn't 0 out until about 2700 rpm, and maxes out around 4lb's of boost in the high 4xxx's. It seems low to me, and i don't know why i read so much vacuum. The gauge 0's out when the car is shut off.
What could be causing this? vac leak somewhere? My vacuum lines are all different sizes. I t'ed the factory line twice, and there's a small vac line going to the gauge, a slightly bigger line to the BTM box, and the factory rubber line is even bigger. Can this be messing up my readings??? Or is it just a leak issue?
Old Mar 12, 2001 | 01:52 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
You should read 0 the second you hit WOT, even at 1000 rpms. Does the gauge read zero if you just disconnect the vacuum line from it? FWIW, I have about 20-22 inches of mercury at idle on a fairly stock L98.
Andris, with a few mods
Old Mar 13, 2001 | 10:36 AM
TheWraith's Avatar
Engine: 355
yes it reads 0 when disconnected or if the car is off
<font face="Verdana, Arial" size="2">Originally posted by askulte:
</font>
Old Mar 13, 2001 | 12:07 PM
Jester's Avatar
High teens-low 20's sounds about right for an almost stock L98. Maybe you need a smaller pulley
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Mar 13, 2001 | 05:27 PM
The ODB's Avatar
try another gauge hooked in a different location, then compare the two.
Old Mar 13, 2001 | 06:49 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
<font face="Verdana, Arial" size="2">Originally posted by Jester:
</font>
He just needs to be careful to not overrev that Paxton SC.. they aren't really known for living a long life when spun at high rpms..
Old Mar 13, 2001 | 08:45 PM
maniacc's Avatar
Wraith,
20" of vacuum is great, you do not have a vacuum leak, as far as the boost, if you have a ported plenum,mini-ram, good flowing heads,etc... all this will lower your boost because the engine can breathe better.
later
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
and NOW supercharged!!!
http://maniac.megamania.com
Old Mar 16, 2001 | 01:49 PM
TheWraith's Avatar
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by maniacc:
Wraith,
later
</font>
that's the thing....the engine is bone stock....stock tpi, stock heads, stock cam, at least as far as i know. It was no record setter before. I ran some 14.6's and 14.7's with it pre-paxton, which is about right.
I should be pushing more boost. I'll move the gauge other places and see what happens.
[This message has been edited by TheWraith (edited March 16, 2001).]
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Bstrang6
Sep 8, 2015 04:29 PM
355sbcTPI
Aug 19, 2015 04:38 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
