thinking about supercharging the 6, need advice.
Old Mar 19, 2001 | 11:13 PM
3.1 firebird's Avatar
I was thinking about getting a blower put on to give my 6 a nice kick in the butt.I plan on a centrifugal supercharger that puts out about 4.5 psi.The problem....no kit available, so I would have to do it myself. So anyone feel free to answer my questions, I would appreciate it very much.
1. With the 4.5 PSI, would the computer/fuel pump/fuel injectors need upgrading?
2 Would I need a FMU?
3. How hard is it making a bracket(s)to mount the supercharger? I;m thinking more along the lines of it being a big PITA, not really something to mind boggling.
4. On the piping that runs from the supercharger to the throttle body there are some kind of rubbery looking things that slide over the piping and get clamped down, what are these and where can I get them?
thanks.
Old Mar 19, 2001 | 11:33 PM
The ODB's Avatar
nitrous is much easier and more effective at adding torque and improving your E.T.
If you must supercharge then I'd recommend the Powerdyne for a low-boost V6 application. Just get a kit and use the brackets it comes with.
The silicone tubing can be had from a hardware store cheap.
A good adjustable FMU should work good enough.
Old Mar 19, 2001 | 11:58 PM
<font face="Verdana, Arial" size="2">Originally posted by The ODB:
</font>
hey since I live about 20 miles away from Belleville, you are going help me right ODB?
Old Mar 20, 2001 | 12:59 AM
The ODB's Avatar
my friend Shawn also lives in belleville. He will do it for you at his house. He also has had 10 second cars and knows what he's doing, plus he needs the business.
you can visit his board here
http://pub48.ezboard.com/bmwsr
where he is 'ta2slow' the administrator, or email him at
sbeach@postnet.com
*I do custom performance mods on Edlebrock Performer carburetors (dualplane intake mods in the works),
White 1986 Irocz, 305 with iron #416 heads,
383 with aluminum TFS heads,
Edlebrock Performer-RPM intake and Performer #1407 carburetor, +110hp shot of crack, 700R-4 tranny, Vigilante 2400 lockup converter, 3.25:1 Ford 9" rear, Mcreary Road-Stars, SLP-stainless 1.75" shortie headers & Y-pipe, single 3" Borla exhaust, Linginfelter-TPI camshaft part number 74216 pulls 17" vacuum solid. Cam specs 213/219 @.050 114-LSA, sometimes advertised at 216/219 @.050 112-LSA .462/.470 lift @1.5:1 ratio. Using Harland Sharp 1.65:1 roller rockers. MSD-6AL, billet distributor, multi-retard, blaster-3 coil, and RPM switch. SouthSide machine subframe connectors, SSM lift-bars, Moroso 4" underdrive crank pulley.
N/A runs 10.9 @124,
Crack-runs 10.3 @135
haven't run at track since Oct-99
* vizit miy homepayge * http://www.geocities.com/trailerparkpage/
Old Mar 20, 2001 | 12:55 PM
sbeach@postnet.com
</font>
cool thanks, I'll shoot him an e-mail sometime. I have to get a job before I can do anything to the car .
Brinkkl2000
Aug 4, 2018 08:29 AM
midge54
Jan 29, 2017 07:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
slade5612
Aug 11, 2015 07:19 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
