OH CRAP, PLZ HELP!!(long)
Old Apr 7, 2001 | 02:52 PM
chevyboy07 91's Avatar
Sup guys,
Last night I went to put the 125 shot jets in and I have a big problem. BTW it's for a TBI. The threads on the back side of the plate (male fitting) are stripped to all hell. I must have cross threaded them while tightening. So, after kicking and screaming I decided to try and find a solution. I looked at the plate and arrived at a conclusion that this piece was irreplaceable and that I needed a whole new plate. So I put the jet in and JB welded the crap out of the AN fiting onto the now stripped threads. I turned it until it was as tight as it would get without turning loose again.
This morning, I checked it out and everything was dried up. I hit the button and now it's leaking from the rear of the AN fitting....but not from the threaded part. So, I'm going to JB weld the crap out of the rear part of the AN fiting now.
If this were to seal properly, will my nitrous shot be just as effective or not? The flare is right on the jet, but it's just not as tight as it should be I guess. And the N2o has nowhere else to go but throught the rear of the AN fiting. Please help w/ opinions, etc. thanks
Old Apr 7, 2001 | 02:55 PM
Ohh, it's too late for me now, but in case this happens to you (knock on wood) I think I have a sure fire solution. Cut/grind the AN fitting of of the line. JB weld the jet to the flare of the line, then JB weld the jet(w/ now attached line) to the plate. I wish I would have thought of this earlier. It seems like it would have worked. Of course, you'd be stuck w/ that shot forever.
Old Apr 7, 2001 | 03:16 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
i would have just hilicoilded it
"its a kit that retreds to original sises"
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Old Apr 7, 2001 | 10:17 PM
I don't think you can heli-coil male fittings.........just females. Anyone else????
Old Apr 7, 2001 | 11:40 PM
JPrevost's Avatar
Car: 91 Red Sled
I wish I could help but I haven't gotten into the No2 thing yet. Keyword is yet. I've just started looking into EPROM burning and then I hope to have saved up enough for a 125 shot this summer. If it were me I would have sent the part back and payed for a new one. Last thing you want is a piece falling into the engine. Good luck!
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
bamaboy0323
Sep 12, 2015 07:14 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
