When should I hit the Nitrous?
Old Jun 10, 2001 | 05:09 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
Transmission: TH700-R4
I was wondering when the best time to hit the nitrous is? Should I hit it coming out of 1st into 2nd(auto)?
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
Thermomaster chip/160 degree thermostat
gutted airboxes/K&N filters
[i]rebuilt 700R4(borg warner/raybestos clutches,Kevlar band,vette servo)[i]
[i]B&M 2400 stall torque converter[i]
Old Jun 10, 2001 | 05:12 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
sorry about the sig.
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
Old Jun 10, 2001 | 06:13 PM
Cosmik Debris's Avatar
You don't say what ratio rear gears you have. This makes a difference. Basically it depends how much traction you have. The sooner you can engage the nitrous the better for your performance but if you just blow the tires away it is a waste of time.
Old Jun 11, 2001 | 09:00 PM
Z28z's Avatar
Car: 91 Camaro Z/28
Engine: 5.7L TPI
I have 3.23s
91 Camaro Z/28 5.7
SLP catback
SLP runners
SLP 1 5/8" headers
TPIS airfoil
Rebuilt 700R4(borg warner/raybestos clutches,Kevlar band,vette servo)
Old Jun 11, 2001 | 11:29 PM
Bobalos's Avatar
As soon as you can w/o getting the tires up in smoke.
BW
Bobalos
aka Bob W.
www.r71camaro.homestead.com
r71chevy@earthlink.net
Old Jun 13, 2001 | 12:06 AM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Transmission: pro-built 700r4: 2400 stall
I have that Prob. any time in first with stock gears
Hecubus
Check out my new site http://www.geocities.com/hecubus91
91-Z28 305 Tpi "G92" mods-- K$N/Foil/Cat Back 3" Flowmaster/3" High Flow Cat/B&M shifter/ Intrax Springs/ Kyb Shock's-Struts's/Poly Bushings/Hotchkis Strut Tower Brace/Nos Wet Plate System currently ~200hp shot/ 155lph Fuel Pump/ Holly Adj. Fuel Press. Regulator/Digital Fuel,Air-fuel, voltage & Oil Press Guage's/MSD 6al/ Blaster coil/ Optima,Yellow top batt.
"I spent all my money on race cars, beer, and Broads... The Rest I wasted"
Old Jun 13, 2001 | 08:57 AM
Bobalos's Avatar
Then either you need better tires, better traction device, or wait until second. Idealy you want to hit it out of the hole. but if the car cant put it to the ground you are going to have to wait a bit.
I went to the track this weekend & towards the end of the day it was getting slippery & I started spinning a bit out of the hole. I lost 2 tenths @ the 60' mark with what felt like just a bit of wheel spin. so if the tires are going up cause of the NOS, imagine how much you are loosing, or better yet, imagine how much you are going to gain when you get the car to hook up . its all about perspective right?
BW
Bobalos
aka Bob W.
Old Jun 13, 2001 | 08:48 PM
Hecubus's Avatar
Car: 91 z82
Engine: 5.0
Right!
that's they way I'm looking at it atleast..
I'm in the process of trying to get some equipment "LCA's and brackets/tires" to help,
that will be insane if I can even get it to stop 1/2 of the wheel spin..
but right now I need a shift kit bad
doing that in the next week or so
what are your susp. mod's Bob?
Hecubus
Old Jun 13, 2001 | 10:00 PM
Bobalos's Avatar
~ Weld in CE sub fram connectors.
~ SSM lift bars
~ CE drag shocks
~ 3.42 gears w/Auburn gear posi
~ MT ET streets.
this last Sunday I was hitting 1.75 60's w/pretty good regularity. towards the end of the day the track was getting slippery & I think that a bit of track bite would have helped that some (along with a real launch pad).
Remember though I am a 2nd genner not a 3rd genner.
BW
[This message has been edited by Bobalos (edited June 13, 2001).]
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
apie2546
Oct 16, 2016 02:24 PM
RS Reaper
Sep 27, 2015 07:04 PM
Twinn Engines
Sep 25, 2015 06:27 AM
