question about nitrous and timing....
Old Jul 8, 2001 | 07:47 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
i have a hypertech chip in my car and i just finished my nitrous kit install. NOS recommends running 1-2 degrees of retard with the juice. from what i understand, the hypertech chip just increases ignition timing. So what do i do? just the timing back 2 degrees retarded or should i take out the chip and get a different one??? i dont have the stock chip so id have to buy a new one. or can i buy like a MSD timing retard or something and just use that only when i spray???? thanks for the help.
Old Jul 8, 2001 | 08:18 PM
MouseCamaro305's Avatar
MSD timing retard would be the best way to go for juiced racing and non juiced racing
Old Jul 9, 2001 | 02:07 AM
Omar's Avatar
I also agree. If you have an ignition box already such as MSD's 6A, get MSD's 8982 timing retard box. If you have no box, look into MSD's Digital 6. Don't forget to look at other manufacturer's ignition boxes also.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Jul 9, 2001 | 05:21 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
i have a MSD 6A box right now. if i get the timing retard box, how does it work??? do you set it for a specific retard and then it waits to retard until you fire the juice or do you have to manually retard it by the little **** thingy??? does it plug into the MSD box? also, how will this work with my hypertech chip? thanks for the help.
1988 IROC-Z L98
License Plate: STG KLR 1
Engine Mods:
Edlebrock TES Headers, Hypertech Chip, Flowmaster Muffler, Intake Airfoil, Removed MAF Screens, MSD-6A, MSD Blaster 2 GM Coil, bored .030 over.
Nitrous System: NOS 05151 Plate Kit with Fogger Nozzels. 100hp shot. Not installed yet.
Suspension Mods:
Lakewood Traction Action Lift Bars, Hal Rear Shocks
Trans Mods:
2,500 stall converter, Redline clutches,Heavy Duty Steels, Trans-Go reprograming kit , Heavy Duty 2-4 band, Corvette Servo, B&M Mega Shifter w/ Carbon Fiber Handle (looks sweet in a black car!)
ET: 13.833@99.30 N/A
"If you can put it on your car, its fair" Quote By Guido
Foundering Member of the Illinois Overkill Crew (IOC)
www.mfba.org
Old Jul 10, 2001 | 02:01 AM
Omar's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 88blkiroc:
do you set it for a specific retard and then it waits to retard until you fire the juice?</font>
Exactly. It retards upon receiving 12 volts to a certain wire. That wire would be the same one that gives 12 volts to your solenoids.
As far as your Hypertech chip goes, you will probably have to pull out a little more timing than you would if you had had a stock chip. Most give a rule of thumb of 1-2 degrees per 50HP. It may be a bit more for you.
1989 IROC-Z 5.7L
NOS 150HP kit
Old Jul 10, 2001 | 08:57 AM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
i have to agree and disagree with you guys.
i have a 305 tbi with a 125 hp shot of juice and a hypertech thermomaster chip and i have my base timing set at 2 degrees advanced and i never have any detonation problems with it and i am on the juice the whole quarter. although you should retard the timing 1.5-2 degrees for every 50 hp increase shot. i have never had any problems and i run Texaco 93 octane fuel, not race fuel either.
Old Jul 10, 2001 | 12:38 PM
well, yeah thats fine, but he stated the topic probably to be on the safe side, 1992- I agree with you- you don't nessecarely have to retard the timing in order to be safe with nitrous, in fact l have a near stock LB9 305 tpi with 70,000 miles on it, and I run 150 HP nitrous at 6 degrees of advance. I've never had it to the track yet, but I've gone through all gears to 4th under juice, and gone through about 12 bottles at 150 with it, still no problems. I do plan however to atleast get an upgraded ignition for it but youre right 92- you really don't nessecarely have to have an ignition box to run nitrous
Old Jul 10, 2001 | 03:01 PM
ATOMonkey's Avatar
If you don't have an AFR or EGT gauge then you really need to learn to read plugs and tune your engine off of that.
'87 Bird 350 .060 over 700R4 + Lots more
CarGuyDennis
137
Dec 6, 2016 11:02 PM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
