please answer..don't leave me hangin
Car: 86 Z28
Axle/Gears: TBD
think its possible to have a 450-500 hp super charged tpi 350 that gets 18 mpg or better(hwy). hopefully better than that. a better question being would it pass emissions in IL? or period.
Super charged people with 4-600hp what do you use for a rear end? 9 or 12 bolt. how does it hook up on street if at all....
"Work like you don't need the money, love like you've never been hurt, and dance like you do when nobody's watching."
Car: '89 Firebird
Engine: 7.0L
Well, since nobody has answered yet I'll chime in about my '94 LT-1 Vette. I had a well built motor with a stock cam and stock computer with a Vortech V1 S-trim at 12 psi. It made 500Hp on pump gas and got 26 mpg in sixth gear on the freeway. It passed emissions with no trouble even with the CATs completely gutted. There's quite a difference in manifold and head design between TPI and LT-1 so it's going to be a heck of a lot harder for you to make the same Hp. But with the proper mods you can easily get there and more.
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Yes. I've gotten 24 mpg from the Z28tt during the drive from MA to NC. Granted, it's turbos, but the supercharger shouldn't be much worse. It's an stock L98 with the T56 in sixth gear and a Super Ram intake. Best trap speed was 114 at 5psi, so its somewhere around 450 hp I think. Fuel economy shouldn't change much if you can keep your foot out of it.
Rear ends - if you'll be drag racing, the 9 bolt/10 bolt will eventually break and you'll need to upgrade to a 9" or 12 bolt. With the stock torque arm, it would spin through 1st and second. With the much shorter Herb Adams torque arm, I actually get traction now. Run drag radials or Kumhos if you always want traction
Andris Skulte
Skulte Performance Designs
Z28tt-89 IROC T56 DFI Twin Turbo
http://www.skulte.com
[This message has been edited by askulte (edited July 25, 2001).]
Andris Skulte
Car: 1987 Z28 Convertible
Transmission: 5-speed
My goal from the very beginning was to have a 12-second emissions-legal, daily-driven 305.
Not only have I met my goal, but my best is a 12.04 @ 116+ mph. I was getting over 19 mpg in town until I installed a 3800 flash stall torque converter. Today, I get about 17 mpg.
Here in Arizona, I have to go through a yearly emissions check which includes a visual inspection and a tailpipe sniffer (at idle and load). I can post my results of the sniffer test if requested.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig) with 50-hp nitrous: 12.043 @ 112.86 mph.
ATI D1SC (10-psig): 12.056 @ 116.62 mph.
All stats are altitude corrected for 3,100 feet using NHRA's Altitude Correction Table.
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited July 25, 2001).]
Willie
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
<font face="Verdana, Arial" size="2">Originally posted by QwkTrip:
There's quite a difference in manifold and head design between TPI and LT-1 so it's going to be a heck of a lot harder for you to make the same Hp.</font>
Car: 86 Z28
Axle/Gears: TBD
ok great now i know it's possible.
mini ram? TPIS hmmm i haven't gotten good news abou them in a while. AFR heads sound good. ummm where can i get info on afr. About how much compression would be needed before i added about 9psi of boost? 12 bolts are an arm and a leg but i'll look anyone know where to get either a 12bolt or 9 inch.
Redcamaro83,
Check out these sites
http://www.airflowresearch.com/main.html
http://www.moserengineering.com/
http://www.martelbros.com/strange/strange.htm
These site might help you out on your quest for info..
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
http://maniac.megamania.com
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
gta892000
Sep 16, 2015 12:37 AM
