What CR are you lot running?
Old Jul 3, 2001 | 01:02 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
A stock 350 runs at a 9.3:1 correct? Did any of you lower it or did you just build it to support the boost?
Old Jul 3, 2001 | 09:17 PM
maniacc's Avatar
I run 10#'s of boost (intercoooled) on a STOCK 350 tpi (9.3:1 comp)...so far no problems (knock on wood)...except the trans is feeling alittle soft now...this winter i'll be getting a new 700r4 and a new converter
Though i do use 24# injectors and a FMU and i do have a good exhaust system
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
http://maniac.megamania.com
Old Jul 4, 2001 | 12:04 PM
GMI FAST's Avatar
I am running 8.5:1 JE slugs. On pump gas I run 18 psi. On VP C16 gas I run 25 psi.
1989 Trans Am
GM tall deck Bow-Tie block
TH400 w/transbrake
Hahn Racecraft turbosystem
NOS dry-fogger kit
Gunnin' for 8's
1994 Toyota Supra Turbo
6-speed, sportroof
11-second daily driver
1994 Jeep Grand Cherokee Limited
5.2L V8, loaded
K&N Filtercharger kit w/cold air intake
Flowmaster cat-back
Pioneer/Polk Audio CD system
FOR SALE!
Member of Midwest F-Body Association www.mfba.org
Old Jul 4, 2001 | 05:01 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
Ditto on what Maniacc said. I'm running the stock L98 engine (with Super Ram intake). I have been getting some significant blowby (as seen from the oil on valve covers dripping out of the breathers), but so far nothing catastrophic. This is with the turbos set at 5psi non-intercooled, and now at 7 psi intercooled (going to nine in a few weeks once I get all the instrumentation set up). I'm running 30 lb SVO injectors and a normal AFPR set at 58 psi (at 0 vacuum).
A.
Old Jul 5, 2001 | 08:29 AM
Omega's Avatar
Engine: LS1 / LS3
Maniacc:
Nice site.. love the maro "next to water" pic. What kind of FMU are you running? Your intake looks like a stock TPI, are you running a piggy back system?
I am going to build a 350 with stock specs, just have the pistons forged and a good crank (what do you recomend?) will i be able to use stock rods?
askulte:
How easy is the super ram to tune and program? Is it a lot of running while recording data and then tuning?
Is there an FMU that allows you to use the stock intake and ECU, but when the stock system isn't able to handle the task, a piggy backed system kicks in? Basically i don't have the money for a SR but will need the versatility.
GMI FAST:
Can i see some pics of your Turbo install?
[This message has been edited by Omega (edited July 05, 2001).]
Old Jul 5, 2001 | 12:49 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Maniacc
How fast are you running with that setup in the 1/4 and how much hp do you rekon you have?
Old Jul 5, 2001 | 12:52 PM
maniacc's Avatar
Omega,
Yes the intake is completely STOCK, no porting has been done. The FMU (fuel management unit) came with the ATI kit, and also comes with a vortech kit, most are adjustable, to aid in tuning, all they do is raise the fuel pressure under boost conditions, this allows for the use of stock injectors, a better way to tune is use a programmable engine management system like, accel DFI, Speedpro, or Motec, and use properly sized injectors.
You can use the stock rods, but if your going up the boost, (you'll always want more boost) i would recommend something alittle better.
just to let you know, the FMU has nothing to do with what intake you are using or ECM
have fun
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
Old Jul 5, 2001 | 03:53 PM
Omega's Avatar
Engine: LS1 / LS3
I just checked Jeg's they sell a Accel DFI Variable Injector Controller. They lead me to beleive that it will run with a TPI system, is that right?
Old Jul 5, 2001 | 05:20 PM
maniacc's Avatar
Omega,
The DFI variable injector controller, is used for fine tuning each cylinder, and needs to work with an already exsisting DFI unit, it will work with the stock ECM, but you will have to have a custom prom burnt, then you'll really have to know what your doing when using the VIC to tune your engine,
there is on other option, that i did forget to mention, you could also ditch the FMU and use a Carroll Superfueler for adding the extra fuel needed under boost conditions
goto http://www.mrgasket.com there is all the instructions and manuals for the DFI system, its under the accel digital fuel management link, you'll also need adobe reader to view these pages
RMK - i have yet to take the car to the track, but but i have raced a ram air t/a and a camaro SS and WON!!!, so my best guess is that i'll probably run around high 12's, and that would put me somewhere in the neighborhood of 350 hp.
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
[This message has been edited by maniacc (edited July 05, 2001).]
Old Jul 6, 2001 | 09:25 AM
Omega's Avatar
Engine: LS1 / LS3
Thanks maniacc, I looked through the Typhoon page a little... interestng stuff. I like the superfueler idea. I am trying to stay away from custom burning chips, but i might have to give in and do so. There was no price listing for the super fueler, do you or anyone know how much it will cost?
Old Jul 6, 2001 | 12:34 PM
Guido's Avatar
Car: 2000 Trans Am
I am running 9.2:1 compression.
Have not had car to full boost yet but will probably see 10-15psi as I had 13psi on last year's motor.
-86 IROC
S-Trim, Speed Pro, AFR
this years goal: 10.50 @ 130+ mph
-=ICON Motorsports=-
Old Jul 6, 2001 | 12:47 PM
Omega's Avatar
Engine: LS1 / LS3
Guido, are you running forged pistons and crank? I am not sure if i should go with a cast, forged or unobtanium crank.
Old Jul 6, 2001 | 03:51 PM
Guido's Avatar
Car: 2000 Trans Am
Yes I have an eagle 4340 crank, eagle h-beam rods and JE pistons.
Old Aug 2, 2001 | 04:21 PM
ImportEater's Avatar
Maniac -- Please, please, please tell me that your intercooler setup didn't eat as much ground clearance as it looks like it did. I've been racking my brain to try to come up with the ultimate (*read - least ****ty*) location for it when I implement my twin turbo setup that I'm planning. I've thought about this location, but I just seems like it would take up too much space down there.
Old Aug 3, 2001 | 01:18 PM
maniacc's Avatar
Import eater,
It looks lower than it really is....the scoop only hangs about a inch below the front spoiler....i have yet to scrape the intercooler scoop, but i still scrape the plastic air dam on everything...
later
larry
Old Aug 4, 2001 | 10:13 AM
Sweet! Thanks Larry, I think I just found my intercooler mounting config for my TT setup when I get it underway.
THANKS!
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Steve78LT
Feb 24, 2016 12:15 AM
355tpipickup
Aug 13, 2015 07:35 AM
