turbo size?
Old Aug 8, 2001 | 05:04 PM
downwithET's Avatar
turbo size?
i took a turbo off of a 88 lebaron 2.2 auto and it looks small. all data says its a t-3 but i dunno, i got all the numbers i could find on the compressor housing if anyone could decifer them i would be mucho happy
TE04H
7F (with a circle around it)
7273423
4387235
and of course it says mitsubishi on it
is it too small for the TT small block?
race it or sell it
Old Aug 8, 2001 | 11:48 PM
downwithET's Avatar
help....
Old Aug 9, 2001 | 10:18 AM
ATOMonkey's Avatar
It depends on how high you're revving the engine. I don't know exactly what those numbers mean, but that's a Garrett turbo. The TO4E is one of the most popular turbo's of all time. Parts like bearings, wheels and houseing should be cheap and easy to find. Two of those should be ok as long as you're not running more than 10 lbs of boost or spinning the engine faster than 5500 max. If you do this make sure that you get an Exhaust Gas Temperature gauge and an Exhaust Manifold Pressure gauge, if you can. It will make as much boost as you want, but your exhaust back pressure might go through the roof and you'll burn exhaust valves. Check out egarrett.com & the best turbo page that I have ever found turbofast.com.au/ That should give you just about everything you need to know.
'89 Red Formula 350- 350 .060 over forged pistons 232* @ .020 cam Performer RPM Holley 750 DP Vortec 1.94 1.50 Accel Coil and dist. Hedman shorty headers Dual Exhaust w/ cutouts 1LE WS6 suspension, wheels, and brakes, 9 Bolt 3.27 Posi Edelbrock LCA's & Track bar subframe connectors 700R4 A&A snorkel scoop Eclipse Head Unit Delco Bose Speakers 2 12" Pioneer subs w/ 400 watt/chanel amp
Old Aug 9, 2001 | 05:04 PM
downwithET's Avatar
i thought there are only 2 companies that make turbos, being garret and mistubishi, so if it says mitsubishi on it then how is it a garret?
Old Aug 10, 2001 | 11:15 AM
GMI FAST's Avatar
The turbo is NOT a Garrett T04E. The turbo is a Mitsubishi TE04H unit, which will support about 250 hp on a 2.0L-2.5L engine. It is VERY small for anything bigger than a 2.5L engine. It would make a nice turbo for your Lawn Boy...
1989 Trans Am
GM tall deck Bow-Tie block
TH400 w/transbrake
Hahn Racecraft turbosystem
NOS dry-fogger kit
Gunnin' for 8's
1994 Toyota Supra Turbo
6-speed, sportroof
11-second daily driver
1994 Jeep Grand Cherokee Limited
5.2L V8, loaded
K&N Filtercharger kit w/cold air intake
Flowmaster cat-back
Pioneer/Polk Audio CD system
FOR SALE!
Member of Midwest F-Body Association www.mfba.org
Old Aug 10, 2001 | 06:32 PM
downwithET's Avatar
GMI i am making a twin turbo and only plan on running 5 psi to begin with and maybe 10 next year, will 2 TEO4H's be enough to sustain 5psi with shifts of 5500-6000 on my small block?
race it or sell it
Old Aug 11, 2001 | 10:16 AM
GMI FAST's Avatar
Don't worry about boost pressure, worry about airflow. You could run those little turbos at 20 psi and not make a lot of airflow to support the engine. Use bigger turbos...
1989 Trans Am
TH400 w/transbrake
NOS dry-fogger kit
Gunnin' for 8's
6-speed, sportroof
5.2L V8, loaded
Flowmaster cat-back
FOR SALE!
customblackbird
Oct 1, 2015 04:30 PM
Linson
Sep 21, 2015 01:08 PM
m00n420
Sep 11, 2015 02:39 PM
timonator
Sep 10, 2015 07:55 PM
BOOT77
Sep 5, 2015 03:55 PM
