SUPER RAM Question
Old Aug 26, 2001 | 11:55 PM
JR4444's Avatar
SUPER RAM Question
I have been looking into buying a complete Super Ram and I wanted to know how har it is to install? I think I can do just about anything on my car, but I'd like to know how hard it was to install. If you have any tips, trouble shooting or if you can tell me any problams you ran into, I'd appreciate it. Thanks.
Old Aug 27, 2001 | 12:43 AM
superiroc's Avatar
1.Take your time
2. you will need to remove a couple rocker arms to get the bolts on the runners
3. leave all the bolts loose untill you get them all started, and take a few breaks when you get frustraded.
4. Make sure you bolt the fuel rail down before you put the plenum on! It looks like you can put the fuel rails and fish THROTTLE cable on after, but you can't.
Old Aug 27, 2001 | 11:32 AM
Bobalos's Avatar
Patience, patience, patience. Super Chevy or someone did a build up not too long ago & they put studs on the bottom of the plenum to go down through the runners & I can see where that might make it a bit simpler to put together, but I have not tried it. I think if I take the motor apart for a cam change & freshen up I will do the same.
BW
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
