Who has blown an engine using only 50-150 shot of NOS?
Old Aug 28, 2001 | 06:58 AM
92fire-audio's Avatar
This goes along with the question I asked about older engines, here's a little update on the situation. If I blow the engine then I have NO car.. What are the chances on a 130,000 mile car that runs good and has correct settings that nitrous will affectively blow the engine?
I want 13s but not bad enough to risk the motor, i just want to make sure it's 99% safe..
Old Aug 28, 2001 | 05:16 PM
Cosmik Debris's Avatar
Well, I'm afraid there are no guarantees but I run a hundred shot on a 130000 mile car and so far so good.
Old Aug 28, 2001 | 11:22 PM
87CamaroZ28's Avatar
I ran a 75 shot on the bird when I had it, it was showing 130,000 on the odo. I had a fuel pressure guage and watched it closely. I stuck with 75 shot b/c the fuel pump couldn't keep up with 125. I didn't have any 100hp jets to try it. I only ran 8 or 10 bottles through it before I sold it but it still ran fine. I was well pleased going from an 8.8 all motor to a 7.9 in the 1/8th on just 75 shot. Traction was an issue also though.
87 Camaro Z28
LB9 305 TPI, Accel cap, rotor, and 8mm wires, K&N filters
1/8 mile: 9.8@69mph
91 Formula
L98 350TPI, Accel 8.8mm wires, Siamese Runners, Edelbrock Headers, Edelbrock 3" Cat-Back, Airfoil, K&N Cone Air Filter, AFPR, Shift-kit, Mallory Promaster Coil, Nitrous Works Wet Kit 75hp
1/8 mile: 7.9@86mph
Old Sep 2, 2001 | 08:59 AM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
100,000 miles. mine is fine for now
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
fasteddi
Sep 2, 2015 10:29 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
