Cutting Pistons for Compression....Good or Bad?
Old Sep 4, 2001 | 09:25 PM
383TAGTA's Avatar
Car: 1987 GTA originally 350TPI 3.27posi
Engine: 383 C.I.D.
At 9.75:1 Compression Ration and Aluminum heads I would like to run a D-1SC for 10psi with 3 core intercooler with my DFI. However, since I'm getting my rotating assembly balance I could cut the pistons to lower my compression then I could run a Supercharger with a good amount of boost. I have all forged internals the very best name brands 4340 Crank, JE pistons, Oliver Rods, 4 bolt main 383 stroker with 195 AFR Fully ported 2.05/1.6 Race heads and a Miniram. So Should I go for 600 h.p with Supercharger or 450 N/A?
Old Sep 4, 2001 | 09:49 PM
blowen90ta's Avatar
i would think nothing of running 10 pounds of boost on your combo with that cr and aluminum heads you will be fine as long as your fuel supply is up to the task and you loose a lottle timimg up top so it dosent detonate.
pete
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger,afr heads, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Old Sep 5, 2001 | 09:14 AM
mtx28's Avatar
dont mill the tops of the pistons to lower the compression.. running pistons with with a small (forgot the term..) thickness on the top is asking for it
83 Z28--not a pretty site, sold thank goodness
74 Z28-- 383/400, green on black. pretty clean. FOR SALE!!!
Old Sep 5, 2001 | 03:31 PM
JAYDUBB's Avatar
Car: 1991 Camaro RS
Engine: L03 305 V-8 (for now ;) )
Transmission: T-5 5 speed
Axle/Gears: stock... whatever that means :)
If you cut the pistons too thin you can easily crack them or burn a whole in them when you start putting added cylinder pressure and heat to them.
You should be OK at 10 PSI intercooled. Have you asked ATI yet? I bet they will say the same thing. Look at this example. A friend of mine built a 420 SBC. It has a 10:1 compression ratio. On the dyno, they were stuffing 7 PSI down its throat (No intercooler, carbureted, 28 degreee TOTAL timing) and it didnt detonate. Mind you his motor has AFR 220cc heads on it.
My vote is that you'll be OK.
PS... You better have a damn good fuel system or else!
[This message has been edited by JAYDUBB (edited September 05, 2001).]
Mickeyruder
Sep 2, 2015 02:45 PM
LittleFranks
Aug 20, 2015 03:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
Winchester1094
Aug 18, 2015 10:23 AM
