Power Brakes on a FI engine
Old Oct 29, 2001 | 11:03 PM
812MANY's Avatar
What's the best way to get powerbrakes to work on a turbo car?
With no vac. how do they work?
I know GNs use an electric motor, I'm looing for something simpler.
Should I modify a vacum pump?
Thanks,
JK
Old Oct 30, 2001 | 01:42 AM
Jester's Avatar
They work by taking your foot off the gas before you try to brake...thus reestablishing vacuum.
Old Oct 30, 2001 | 04:38 PM
812MANY's Avatar
What about when I'm trying to balance the car in a corner while trying to keep the boost up?
Old Oct 30, 2001 | 07:31 PM
Hellraiser's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 812MANY:
What about when I'm trying to balance the car in a corner while trying to keep the boost up?</font>
Try installing an aftermarket vacuum reserve canister, jegs and summit both sell them.
Old Oct 30, 2001 | 10:17 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Make sure your check valve at the vacuum reservoir is in good condition. If the vacuum booster does not hold enough add an add on unit like mentioned above.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
EFI Performance Club on Yahoo
[This message has been edited by IROCKZ4me (edited October 30, 2001).]
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
stalkier
Aug 13, 2015 12:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
