is this true?
Old Nov 1, 2001 | 09:04 PM
89FormulaL98's Avatar
is this true?
i heard if you had a blower or a turbo... u could use a small shot of NOS(50-75 shot) and it would act as an intercooler. would this work or is this BS?
Old Nov 1, 2001 | 09:21 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
yes it is true.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Nov 1, 2001 | 09:58 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
the NOS works great on my car as an intercooler
but you still need to add more gas.
check it out at:
http://darcom.home.texas.net/
388 SuperRam, DFI, Vortech R trim ,N.O.S.,alki injection,
Dart sportmansII heads,50 pound injectors, Headman full headers
duel 3' exhaust,and Flowmasters, Ford nine inch with 370's
Ronal rims with Nitto drad raidals.
Old Nov 3, 2001 | 03:54 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Yes a moderate shot of Nitrous/Fuel would absorb any extra heat in the air/fuel charge,
created by the blower. Like an intercooler or water injection. Especialy a Nitrous/methanol injection system. Also it would eliminate any turbo boost lag. Just remember the fuel part would have to be referenced to the boost pressure if the system is post turbo. Done right it could allow more boost to be run on street gas and provide more power with less detonation.
[This message has been edited by F-BIRD'88 (edited November 03, 2001).]
Old Nov 3, 2001 | 09:06 AM
Guido's Avatar
Car: 2000 Trans Am
It also greatly increases the oxygen content in the mixture and under boost you better make sure you have a good fuel system and injectors than can either handle really high duty cycles or flow lots at normal pressure. If not, you will go lean and burn holes in pistons, etc.
-86 IROC
-=ICON Motorsports=-
Old Nov 13, 2001 | 05:13 PM
dwang's Avatar
it's kind like water/alcohol injection, nitrous can be consider as kind of force induction, since it force more oxygen into the engine.
on an interesting note that John Linegefelter use nitrous to cool off the intercooler(due to extrme high boost level) while he attemp a land speed record(it's a thirdgen bird ).
anyway, i conside water/alcohol injection, ice cool intercooler, nitrous intercool as one shot/band aid fix. in a well design turbo system u shouldn't need it, unless u are at the strip.
dw
Old Nov 13, 2001 | 08:40 PM
Car: 1991 Firebird
Engine: 427 LSX
Well, I could just copy the posts of everyone else but then I would not be original.
1991 Firebird
AFPR,Lakewood lcas
AFR 190s
autopower rollbar
Old Nov 14, 2001 | 05:54 PM
IROCKZ4me's Avatar
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
Like everyone else I have to say yes.
It may be worth pointing out that a wet system cools the intake charge better than a dry system.
PS:
It never ceases to amuse me what people call "band aids"
Does a band aid = using a power adder??? Shouldn't a properly designed engine make enough power without it? Do I need slicks or will a properly set up chassis mean I don't need those band aids?
"Band aids? These aint no stinkin' band aids."
I would like to see the band aid that gets you a full second or more in the quarter. I'll take a box of those. Can I get them with pictures of the Flintstones on them?
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
  • 355 cid
  • AFR heads
  • Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
  • modified SLP runners
  • TRW forged pistons/ceramic coated
  • fully balanced
  • Edelbrock headers/ceramic coated
  • SLP cat-back
  • Paxton supercharger
  • Nitrous Express nitrous oxide
  • Lots of more goodies
EFI Performance Club on Yahoo
[This message has been edited by IROCKZ4me (edited November 14, 2001).]
Old Nov 15, 2001 | 07:36 PM
JucinGTA's Avatar
Thought I would add HEHE!!
For supercharged or turbo
applications where nitrous
is not an option, NX offers
another alternative. Tne
"N-tercooler". Using either
nitrous or CO2, this unit can
reduce air inlet temperatures
dramatically. In a recent dyno
test a turbocharged Honda
equipped with an NX
"N-tercooler", increased its
baseline by an astonishing 52
HP! If it makes horsepower
it must be Nitrous Express!
Old Nov 16, 2001 | 01:08 AM
dwang's Avatar
<font face="Verdana, Arial" size="2">Originally posted by IROCKZ4me:
PS:
</font>
what u trying to say? i don't consider power adder as band aid. I stated that if you are race your car @ strip or going for a land record. then using nitrous injection as way to cool the intake charge is very well justifify. but in a daily driver just using nitrous/water/alcohol injectiion to keep a force induction engine from dentation is unacceptable. that is what i mean by a band aid fix. i am big fan of power adder, it allow the engine to be more efficient, hence make more power which is what we are all after.
regard
dw
okfoz
Oct 13, 2015 02:19 PM
mattcanty
Oct 12, 2015 11:08 AM
91 SrS
Oct 7, 2015 04:32 PM
paul_huryk
Oct 1, 2015 04:27 PM
Djmathis123
Sep 8, 2015 08:42 PM
