Just bought ATI D1SC need advice
Old Nov 18, 2001 | 12:48 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Hi guys,
Ive never really come into the poweradder board before, but here's the scoop. I just bought the D1SC to put on my L98, however i plan on rebuilding this winter, what modifications do you guys recommend as far as doing the rebuild, what heads, cam combination is good, do i need new pistons, what do you suggest without going overboard, it's just a street car, and basically a daily driver in the summer.
P.S. The guy i bought the SC from didnt include the intercooler, how much could i pick one up for ?
1991 Z28 Modifications: 17x9.5 Tourque Thrust II's on dunlop sp 5000's, 3" cowl hood, repainted Red/Black racing striped all the way down to GFX, Pro-Kit lowering springs, KYB GR2's, Suspension engenering poly tie rod kit, Autometer dual guage pod with air/fuel and trans temp, Macewen white face layovers, Panasonic DF 88, Reactor 5" Tv, Plastation 2, K&N's, tpis throttle body airfoil, 3" pipes through high flow cats... no muffler, ATI procharger D1SC
Old Nov 18, 2001 | 02:19 PM
Kandied91z's Avatar
intercooler is quite expensive; you should get one new or in very good condition. preferably two would be your best bet; but that depends on your budget and amount of boost your looking to achieve.
Old Nov 18, 2001 | 06:28 PM
91Z28's Avatar
Car: 91' Z28
From what i read i can only go about 5-6 psi on my stock engine, and with a intercooler i could go about 9-10 i would definatly buy the intercooler, what would you suggest as far as a rebuild ?
Old Nov 19, 2001 | 01:15 PM
91Z28's Avatar
Car: 91' Z28
TTT
Old Nov 19, 2001 | 05:23 PM
jethro's Avatar
I would look on ebay first though... they have had a slew of intercoolers for sale... VERY cheap.... I don't know what kind of compatibility problems there are... Anyone?
Old Nov 19, 2001 | 07:33 PM
maniacc's Avatar
You can kit the intercooler kit through ATI with all the piping for around $1000, i would check with some procharger dealers you might be able to get it cheaper through them.
As far as the engine goes keep the compression down around 9:1, get forged pistons, good set of heads, and a special ground blower cam.
Later
Larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
ATI procharger D1sc 10#'s boost, edelbrock TES, complete MSD ignition, Borla cat-back, KB subframe connectors, accel 24# injectors...and a few other go fast goodies
Best E.T. 13.417 @ 106.89 mph on worn out street tires
http://maniac.megamania.com
Old Nov 19, 2001 | 10:22 PM
91Z28's Avatar
Car: 91' Z28
About intercoolers, are all intercooler Air to Water ? please briefly explain intercoolers Thanks Guys !
Old Nov 20, 2001 | 04:20 PM
maniacc's Avatar
intercoolers can be many different variations, most ATI IC's are air/air, most vortech IC's are air/water.
air/air IC's are better for the street, as you have a infinate supply of air to cool the IC, and the colder the ambient temp the more effective the IC becomes. The down fall to these IC's is your restricted to the outside ambient temp, so if it's 100 degrees outside, you'll only be able to cool the intake charge to slightly above 100 degrees.
Air/water IC's are great for the track and consistency, put in ice cold water into the reservoir and your ready to go.
hope this is of some help too ya
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7 TPI
MoJoe
Sep 15, 2015 12:50 AM
86IROC112
Sep 7, 2015 01:37 PM
pimprs
Aug 24, 2015 11:20 PM
johanlindgren
Aug 16, 2015 12:16 AM
