Help-How to construct 12sec cars
Old Jun 26, 2006 | 06:14 PM
Dmitri's Avatar
Car: corvette 87
Engine: 383
Transmission: 4L60
At me has appeared Corvette C4-91, ZF6, gear 4.1, engine 383, comp 11:1. I would want that but went 1/4 for 12sec. I shall precisely use MR, I do not know what to use heads and a cam. Who has a similar experience, wish to hear your opinion. Maine advice on selection parts is necessary.
Old Jun 26, 2006 | 06:27 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
This forum is for 3rd gens, not corvettes. Check out a corvette forum.
Old Jun 26, 2006 | 06:34 PM
Dmitri's Avatar
Car: corvette 87
Engine: 383
Transmission: 4L60
Yes I know. I need to understand at what specification it is possible it is achieved in result 12sec.
Old Jun 26, 2006 | 06:57 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Traction is half the battle engine is the other half... half your problems can be solved on the corvette forums, we can solve the engine half... But one will not work without the other...
its alot easier to tune a car when it hooks...
Old Jun 26, 2006 | 07:32 PM
Sonix's Avatar
Car: 1982 Trans-Am
I think a corvette forum can tell you how to setup your corvette to run 12 seconds. It's a different rear suspension set from our 3rd gens, so asking here is a waste of everyones time.
Motorwise, do a search. A 383 like you say you have, should have NO problems running 12's.
Old Jun 26, 2006 | 10:29 PM
Steven89Iroc's Avatar
Why would you post about a naturally aspirated Y-body in a forum for forced induction F-bodies?
Old Jun 27, 2006 | 03:49 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
Its his ESP telling him to get a thirdgen :P
Old Jun 27, 2006 | 09:00 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Hey Dmitri, must be difficult to build American horsepower over there. I wish I could help you more, but I am not an engine building expert myself. There are a lot of good parts out there that can easily get you to your goal. I don't know how easy those parts would be to get in Moscow, but I wish you luck with your Corvette. I'm sure somebody here will be able to help you out. Also, use the search feature at the top of this page. Don't be afraid to copy somebody elses combo that has already achieved the results you desire.
Old Jun 28, 2006 | 08:48 PM
Project84TA's Avatar
Car: 85 Camaro IROC, 88 K-1500
Engine: 357 TPI, 350TBI
Transmission: T-5, NV3500
Axle/Gears: 3.42 posi, 3.73 i believe
i dont know if this helps but when your selecting a cam, knowing its a 383, you cant go too aggressive (not sure what the max. limit is) because of the stroker crank clearance. dont know if you already knew this or not but, good luck.
Joe
Old Jun 28, 2006 | 10:14 PM
nelapse's Avatar
Car: GTA
Engine: 383 HSR
its not that we dont want to help you... its just we arent vette experts
Old Jun 30, 2006 | 04:11 AM
83 Crossfire TA's Avatar
The setup you described should be deep in the 12’s if it’s tuned right.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
