IS THIS BAD...
Old Aug 5, 2006 | 12:04 PM
carbed87's Avatar
Car: 1991 t/a black on black
Engine: 350 tpi
Transmission: 7hunR4
IS THIS BAD...
ok so i have a 91 t/a, l98 with a paxton sn-89 blower on it. the way the breather system works is the left and right valvecover tie together then circulate into the front of the air cleaner.
anyways, so last night i was romping on it quite a bit, and noticed that it was smoking out of the hood a little bit... no big deal, just some oil on the valvecover (my driverside breather doesn't seal too good) so we drive home and all the sudden it starts running REALLY rough at idle, kinda like it has a cam or something, so this morning i take a look at it and don't find any vacume leaks, and i thought i might have fouled a plug, but i still have plenty of power, so i was stumped...
so i pulled of the air cleaner to find a trail where oil had been going through the intake system, supercharger and everything.
so my question is: have i found my problem, could oil going into the intake make my car run rough, am i going to have to tear my motor apart and clean it out or can it just burn off.
please help guys, i don't know what the hell im supposed to do here, so any input would be appreciated. THANKS,
mike
Old Aug 5, 2006 | 06:38 PM
carbed87's Avatar
Engine: 350 tpi
i was just thinking... would this be considered blowby... if so, then what do i need to do to get my car road worthy again.
Old Aug 5, 2006 | 07:12 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
ya it probably just blow-by. around here a few of the turbo guys are running a oil seperator in the line to keep most of the oil out of the intake. you could do the same thing to keep the oil out of the blower.
Old Aug 5, 2006 | 07:23 PM
carbed87's Avatar
Engine: 350 tpi
oil seperator... do you think you could enlighten me a little bit
Old Aug 6, 2006 | 05:04 PM
carbed87's Avatar
Engine: 350 tpi
anyone... i'd like to get this on the road as soon as possible
Old Aug 6, 2006 | 06:11 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I'm over at SVT Performance quite a bit and there's really good info on making your own oil separator in this thread:
Make your own Oil Seperator for $21 - SVTPerformance
Old Aug 6, 2006 | 07:03 PM
carbed87's Avatar
Engine: 350 tpi
ok, so im guessing i should put that on the side with the pcv valve and keep an open air breather on my drivers side... right. lol im sure you guys have been in my shoes, i mean, this is the power adder board right.
Old Aug 6, 2006 | 07:16 PM
Willie's Avatar
I haven't seen a whole lot of discussion on this here but a ton with factory supercharged Fords. I plan on doing this on my driver's side PCV on my TT IROC-Z very soon!
I cannot run a breather on my passenger side as this changes a closed system into a partially open system which is illegal on AZ. I run my passenger side valve cover breather to the inlet of my passenger side turbo to keep the smog police happy. I will be installing a second oil separator on this line at the same time I add one to the driver's side.
Willie
Old Aug 7, 2006 | 04:06 AM
83 Crossfire TA's Avatar
First, if this just started and it started with it running rough I would suspect that you hurt some thing causing the blowby. First thing I’d do is the choo choo test, pull the oil filler or breather from the valve cover and see if you get any smoke coming from it while the car is idling. If it looks like a steam locomotive then you probably hurt a piston/ring which is causing your blowby.
Old Aug 9, 2006 | 11:33 PM
carbed87's Avatar
Engine: 350 tpi
damn, well then how do i fix it other then re-ringing the damn thing. can i just take the charger off and call it good... lol im running out of options now. and yes, the choo-choo test is a positive.
Old Aug 11, 2006 | 07:30 PM
carbed87's Avatar
Engine: 350 tpi
anyone, sorry im dragging this on, but i kinda need to find this out.
Old Sep 5, 2006 | 03:37 PM
Well, if you’re doing the choo choo thing then the next thing to do is to run a leakdown test to find exactly where and what you hurt…
67 Camaro 88
Oct 4, 2011 06:12 PM
Incoming
Dec 4, 2004 09:06 PM
mvftw
Nov 3, 2004 09:36 AM
Jaswir
Mid-West Region
Oct 19, 2004 10:38 PM
dream02transam
Aug 25, 2004 03:23 PM
